Watching this project slowly come together is very inspiring!
| Color | Before Recap (V) | After Recap (V) |
| Green | -8.11 | -8.22 |
| Red | 13.48 | 13.51 |
| Orange | 5.33 | 5.32 |
| Yellow | 14.01 | 14.02 |
0000000F 00002802.| Pin | Expected (V) | Measured (V) |
| 5 | -12 | 0.0 (!!!) |
| 6 | 5 | 5.00 |
| 7 | 12 | 12.72 |
| 8 | 12 | 12.72 |
The analog board was pretty easy peasy from what I recall from working on mine. Even used hot glue on the caps so they wouldnt move around and break solder joints. Felt super professional and fancy afteword lol.Yup, that is what I found as well.
I realized that I did not recap the analog board yet, so that is the next step.
That would be quite the undertaking. It would be really difficult to price them low enough to make it worth the cost of parts and time. I think it would have to be a labor of love for someone with ample free time.@schrockwell if you get to the point of selling any completed board builds, I think you'll have some buyers! I'd like to get in line![]()
I recapped the CR-44 power supply with the kit from Console5. All went well. Thank god for the Hakko; I got it done in just 90 minutes.
Here are the output voltages, unloaded. No major changes.
Color Before Recap (V) After Recap (V) Green -8.11 -8.22 Red 13.48 13.51 Orange 5.33 5.32 Yellow 14.01 14.02
After reassembly, the problem persists. I managed to capture a short video:
Sometimes it plays a complete chime and shows the cursor, but then freezes. Other times it just shows garbage on the display, or the display is blank. Definitely feels like an intermittent failure of an analog component.
I also got an error code once:0000000F 00002802.
I checked the voltages on the floppy connector:
Pin Expected (V) Measured (V) 5 -12 0.0 (!!!) 6 5 5.00 7 12 12.72 8 12 12.72
Note that there is NO voltage on pin 5, where -12V is expected.
Could that be the culprit? Maybe a bad voltage regulator in the PSU?
Thanks, I checked both of these things. I even asked my wife, who has experience with electronics QA, to look it over. No improvement, unfortunately.I’ve had an issue like this. Couple of things to check - solder work around the GLUE chip (possible poor connection), and sagging 5V line (possibly causing a twitching reset line).
When you come to recap the analog board, check all the sockets for dry joints on their pins.
New oscillators came, no change or improvement. The C32M line at pin 1 of UI7 still looks very wrong - it's the correct frequency, but a triangle wave from 3.2-4.3V which is definitely not TTL levels. So I still suspect something is still wrong with the clock generation, perhaps UH7?
I also noticed after being powered on for a few minutes, the 68030 becomes very warm, bordering on hot.
Check the connections to UH7 carefully. The footprint on the Reloaded board makes it difficult to solder as the pads are almost completely hidden by the chip, so poor connections are common. Check to make sure that adjacent pins aren’t bridged, too.
That doesn’t seem right, the 030 chip hardly gets warm on my boards.
