NanoMac, a candy bar sized FPGA Mac Plus / PlusToo
M and Max are both fabulous applications the deserve to be preserved, I'm so happy to see this work being done. Another one is Opcode Galaxy, which is an editor and librarian for hardware MIDI synths, much like Sound Diver.
<snip> love to know more about programming possibilities (and limitations) at that time.<snip> Would be great to hear more of your experiences on this.<snip>
I'm really amateurish I'm afraid. I have Grade 5 music Theory in the UK and I passed grade 6 Trumpet (a long time ago). I can hack my way through modern worship songs on a piano/keyboard, so you're way ahead of anything I've done. I've had a little look for the Lime manuscript editor on the Macintosh Garden, but couldn't find it. I've also had a look for my DX100 Mac editor and again, haven't found it yet. I'll search deeper in my catalogue of Zip disks!
-cheers from Julz
With minor modifications the NanoMac can generate a video signal identical to the one of the real thing. This it should be possible to drive the original CRT with it.
Same goes for the keyboard and mouse. Wth a little effort it should be possible to wire them to the FPGA as well.
-cheers from Julz
@jgardner : I've searched through all my Zip 100MB disks, but couldn't find it. But it could be elsewhere, I tend to just keep everything I've used so it might be on a backup somewhere or another HD or maybe even my Zip 250MB disks.
Let me know when/if you find it! Would love to give it a try. I don't have a DX100 (yet), but I do have a TX802, and Yamaha made it generally pretty easy to convert one FM library to another I think, especially between the 80's models without internal FX etc
This would be pretty incredible actually. The keyboard and mouse would be the most useful to me at the moment, but having a modern board interface with a CRT is pretty revolutionary in this moment I would say. I've seen people use original mice and keyboards before with FPGA's but never a CRT aside from the regular composite, s-video and RGB signals.
Ah I have to try Opcode Galaxy still, sounds interesting for sure! Yes there is a wealth of other incredible software for the mac. Here's a good article on some of this history worth preserving by artist Kristen Roos: https://clotmag.com/oped/intelligen...ehind-vintage-algorithmic-sequencing-software.
I found most of this type of software via Muzines, which has an incredible archive of music technology magazines where the software was reviewed and tested. Very interesting to read how these innovations were perceived at the time. The archive has been OCR'd with images, so all these reviews are now pretty easy to search through and dig for information on hardware or software from the time.
I also developed an Arduino based sound editor for my Yamaha TQ-5. Those things were amazing: a multitimbral DX-11 + Digital effects synth module, but packaged in an archetypal 1990s design, so ugly eBay sellers would pay you to take it off their hands!
But it's a true synth too. You can roughly edit sounds using the keys on the left, but full editing is possible though MIDI and the parameters are a superset of a DX-21.
Thanks! As it happens I later found a copy of an early version, Lime Demo 1.0 or so that runs on a 68000. I'll post that soon.
Please do! At the time, I was only using DMCS and when it came along, Finale (which I despised from the start). I'd be very interested to see someone else's idea of what notation software could look like. https://www.cerlsoundgroup.org/cgi-bin/Lime/Larchive.html has 7.42, but I'm pretty sure that only went back to 030 or 040? I know I tried Lime a decade or two ago, but unfortunately I can't remember anything about it (and it didn't make my short list of notation/engraving tools).
And hey-presto, here it is! LimeDemo1.1 runs on a 68000 Mac too!
Here's some other versions, if someone's got the time to grab them from the archive:
http://web.archive.org/web/*/http://www.cerlsoundgroup.org/* (use the filter hqx to see the Mac files).
Looks like it has versions 6.0.0, 7.0.3, 7.2.7, 7.4.2, 8.0.0, 8.4.1 beta, and 9.0.0. 8.x and later appear to be PPC-only, and possibly OS 9/X only.
Unfortunately, http://www.cerlsoundgroup.org/cgi-bin/Lime/ftp/mac/ never made it into the wayback engine, or we might have more versions archived.
Yes, they only seem to list much later versions than the one I used.
Has anyone successfully ordered the PCBs for the "MiSTeryNano Shield for Tang Nano 20k" (https://github.com/MiSTle-Dev/Boards/tree/main/misteryshield20k_lite) from JLCPCB?
My issue is that after I upload the Gerber, BOM and Placement files for ordering, some of the components are shown wrongly rotated and aligned in their previewer. I don't assume that Till made a mistake when exporting the files from KiCad, I strongly assume that I did something wrong, as this is the first time ever that I order something from a PCB manufacturer.
Rotation of IC wrong and the USB connector is misaligned:
Tang Nano 20k Pin headers not shown at all, just a checkered cube instead:
Can anyone give me a hint? Should I manually edit the placment file to correct everything or is this just some weird problem with their viewer?
I had similar issues during an (extremely cursory) attempt with JLCPCB a while back. IIRC, part of the issue was that JLCPCB didn't offer some of the parts in the BOM, but had suggested replacements which needed different orientation coordinates.
I was able to manually adjust things to fit, but I was too chicken to actually submit an order and see what popped out.
