Ladies and gentlemen, my next trick is impossible improbable...
It seems like the IWM is the only (or at least the biggest) thing standing in the way of a Plus or SE made of entirely new parts - and possibly also the biggest problem for those trying to revive an old board. For completeness's sake, I will acknowledge that there are a few projects (pldSCHWIM, Shim-IWM, IWMLess) that approximate a "null" IWM well enough to make a Mac boot... but don't actually emulate its functions. I want to go further. What I have my sights on is something that walks and talks like an IWM as far as the Mac's bus is concerned but, instead of connecting to a real floppy drive or HD20 or a simulacrum thereof, emulates drives within itself - a Floppy Emu with the middleman cut out, if you like. I've been doing some reading about the IWM and the Disk II and I'd like to start a conversation about this, if you guys will indulge me.
I didn't realize this before now, but the IWM is more than just a single-chip Disk II. Each bit in the IWM's "mode register" that is set to 1 enables a feature that the Disk II didn't have - to wit, the ability to run with an 8 MHz clock (instead of a 7 MHz one), the "fast mode" that enables a 2 µs bit cell (instead of a 4 µs one), the asynchronous mode that buffers the shift register, and the optional disabling of the one-second timer. I suppose my main curiosity is, does the Mac just set-and-forget all these bits? That is, can I safely drop the Apple II mode of the IWM? Doing so would make the task quite a bit easier...
I'm skeptical that it's possible to do this without two chips working in tandem - a microcontroller and a programmable logic device of some kind - so a true drop-in replacement à la the SE's ADB controller is out of reach, but perhaps a PCB module that sits in place of the 28-pin DIP is possible. That and/or integrating a two-chip solution is relatively painless on a wholly remade board such as @max1zzz 's ITXPlus...
Thoughts? =)
Oh, and by the way, if you can afford it, do chip a few bucks to the Internet Archive, it is impossible to overstate how valuable the stuff they've archived is to hackers and hobbyists like us...
Thoughts? =)
