Thankfully I'm far too broke to be able to afford Amigas so that's not an issue I have to deal withYeah. To see a glimpse of how ugly it could be, look at the Amiga community. Compared to that, things don't look so bad here, even at their worst.
Ha! If the Amiga community is really as toxic as I've heard, that's probably a good thing, as you suggest!Thankfully I'm far too broke to be able to afford Amigas so that's not an issue I have to deal with![]()
Just came acrost this program, I have had the bluescsi for awhile. I just came across this program today. I've found the default blueSCSI tool really hit and miss, for some reason it completely ignores some files. Based on the post here it sound like the program should work with most forks but the github only says zuluscsi and scuznet. This will work with my bluescsi or do I need to get a different emulator?
It should work fine, like @Daniël described the toolbox is (nominally) the same across devices. I'd be happy to add BlueSCSI to the list once someone tests it out, I don't own one to use myself and I haven't heard of anyone trying it. If you do, it'd be awesome if you post the results!This will work with my bluescsi or do I need to get a different emulator?
I should have responded earlier to this addition and the work @Arbee did to get the backing added into MAME. It is a super-cool feature for the emulator and I'm glad scuzEMU has been working well for people. Thanks Arbee!I've been really enjoying using scuzEMU with MAME. Great to be able to test run configurations there before moving images to actual hardware, and know things will work exactly the same on the hardware.
