I looked at the Biege board I have some time ago and I think I spotted the oscillator that drives the PCI clock, and some other stuff.Without quoting anything in particular, I have an XLR8 G4, it's clocked in at 500Mhz, I put a fan on it because it makes an uncomfortable amount of heat in a beige G3 tower case. I also have the BUS speed up to 83Mhz, which seems to matter more than increasing the CPU clock any higher. I'll try a higher PCI clock, but I'm not sure 3Mhz more is going to increase video performance enough to matter.
Replacing the oscillator with a 33MHz part should run the PCI Bus at 66MHz, but then we need a 100MHz rated XPC106 to have any hope of running the systems bus at 133MHz as the 2x jumper setting would allow.
The real issue is Perch, the built-in ATI chip, and Mac-io.
Perch isn't really an issue unless you have installed PCI devices on it that will not work at 66MHz, the ATI chip can be removed if it's an issue, but Mac-io is the trouble, it don't not list as 66MHz capable, but that doesn't mean it won't function at 66MHz, but it's iffy and if we lose that, we lose all the built-in devices that sit behind it.
Some people have had luck with 66MHz PCI hacks on other old world Macs, but it's a crap shoot at best.
Whenever I get around to getting a 100Mhz XPC106 reworked onto a Beige board, I'll let everyone know if PCI 66Mhz will work or not, and what the drawbacks are.
The other issue is I've not found any PCI USB/FW cards that list as 66MHz capable, and we hate to lose that functionality. Maybe some of the PCI-E combo cards are, I'll have to check, as I do have a bridge that is 66Mhz capable.
All wonderfully worthless, I just want the fastest Old World Mac known to man!
