The Noctua fan already made it here, hoping to get this all going tomorrow.
What Noctua fan did you order? I'm looking for one for my SE/30 to make the system quieter.
I bought the 5V fan in error, and then waited for Amazon to stock the 12V again for over a month, they have plenty now.What Noctua fan did you order? I'm looking for one for my SE/30 to make the system quieter.
Oh those ceramic caps are really tricky.I nearly installed (2) caps backwards in the logic board, again. No hot polyester confetti party this time though, didn't power it up backwards.
Couldn't believe I did it the first time on the SE logic board (same two caps even C18, C11), C18 popped and stunk the house up for an evening. Guess that wasn't a strong enough reminder, from just last month.
Fixed now: the chamfered end is + positive, can't seem to remember this.
Floppy grease should be here soon.
Was watching the JDW video for the 1.44Mb floppy, and he recommends using Dow Corning EM-30L lube for the entire drive. Just ordered some from here in California, hopefully it gets here soon.
Ebay has a decent selection, went with the Japan Molykote, instead of Dow Corning, got one from CA, as opposed to NJ, was trying to get it quicker.Where did you order the EM-30L? OOS on Amazon.
Before you give up on those pads, use an X-acto knife or similar to gently scrape it. Use lots of wick and flux to clean it. If there is copper left, apply fresh solder, repeat process. If its totally shot, then yeah you may have to solder a bode wire to the nearest good trace.Having a lot of trouble trying to uncover those traces that were blackened. Can't get solder to stick to those two pads.
