PPC740L G3 CPU Daughterboard For Blackbird Powerbooks
You were going to try it out on a PowerBook 1400 series CPU card that you recently acquired, I think?
I was, until the realization set in that the 133MHz card is in fact not a 603ev, but a 3.3V 603e...
Only the 167MHz is, and thus runs at a lower 2.5V, and that one apparently also needs a matching logic board, which I guess is to do with the power regulation.
Well, at least it'll allow me to sell the PB1400CS on with an included upgrade :-P
I may have found another source for a 745 that doesn't break the bank, so I'm currently pursuing that.
It’s true, the 133 is a 603e not ev. I didn’t know there was a voltage difference. The 166 needing a matching logic board though is to do with the ROM version.
So the next move is to try another 745? Hmm and would it be so bad to try the 740L at 2.42V?
Because 2.2V is the rated max for that chip.
I have actually tried it, but it didn't boot.
No magic smoke, but it's inconclusive to say whether the 740L wouldn't work at all, or if the above max rated voltage simply is too much for it.
Knowing that the buck converter swap also doesn't work, I'm just dropping the idea of trying to get a lower voltage chip working, and sticking to a 745 that is rated for 2.5V max.
It's a matter of eliminating as many variables as possible.
hang on a tick, the 166 needing a matching logicboard due to the *BootROM* is very interesting
do you have any more details on that, ie do you know what happens if you try a 166 card in a 133 logicboard?
this is quite interesting because the 603e and 603ev do have different PVR versions (processor version registers)
and one of the things I was wondering with all of this is the BootROM side, generally older Mac BootROM's are not fussy about the CPU type, so you can stuff any old PowerPC CPU into a PowerMac 7500 be it a 601 604 604e 604ev 750 or various flavours of G4
but I do wonder if in this particular case the BootROM of these PowerBooks is unhappy with the G3 CPU for one reason or another?
(tho there were 1400 G3 upgrades of course, and I think those used a stock BootROM?)
hang on a tick, the 166 needing a matching logicboard due to the *BootROM* is very interesting. Do you have any more details on that, ie do you know what happens if you try a 166 card in a 133 logicboard?
I do, because I tried it. I had two PB1400 motherboards. The first one, from a PB1400cs had a 117MHz CPU and the earlier ROM (which I didn't know about at first). That PB1400cs was barely functional, with 16MB of RAM; 750MB HD; a fairly dodgy CS screen; crackly speaker; no CD or FD in the other drive bay. So, I bought a spares/repair PB1400 from a guy in France on eBay. It didn't work. However, it had 16MB of RAM which could be made to work; an active-matrix screen (which I swapped in) and a better speaker (which I eventually put in the first one). I did, however, find that my 117MHz CPU worked in that board. Later I acquired another 16MB of RAM, from eBay, but the seller also sent me (for free: Thank you!!!) a 166MHz CPU.
I found the 166MHz CPU didn't work in my, now fairly functional PB1400c, but it did work in the other PB1400 (now cs). The difference was the ROM. Here's the thread:
From the thread it's worth looking at this post:
To quote: "I have an underclocked 166MHz CPU card @133MHz in my 1400c because I have the older logic board." This gives a definitive answer, if you under clock a 166MHz CPU and put it in an older logic board (with the older ROM) it can work.
interesting! so a 166Mhz 603ev CPU card *will* actually work in a 1400/117 machine but one might have to twiddle with the card to get it to work
so its not that its fundamentally incompatible then, which is what i was wondering about, because again there are much faster G3 upgrade cards for the 1400 that work in all revisions of 1400 AFAIK?
I would love some more details from that from @croissantking ie what does it do if its clocked back up to 166Mhz etc :)
Hey, so if you install a 166MHz CPU in a 1400 series logic board with an early ROM, it won’t boot - i.e. it powers on, but doesnt chime or anything else. The same behaviour as if the CPU is not installed.
You can fiddle with the resistors on the 166 card to set it to 133MHz which is what I did and then it does boot and work just fine, and is properly detected as a 603ev.
Later on, I got a donor board with the late ROM and I swapped the chips over. I then set the CPU card back to 166MHz and it worked fine.
The issue is that the earlier ROM does not support the 5x multiplier that the 166 CPU needs, it’s not fundamentally incompatible. I wonder how the G3 upgrade cards would have gotten around the multiplier limitation.
Is it 5x, or 5x and above?
If it's only the 5x multiplier, then that wouldn't be too much of an issue for 200MHz+ G3s.
Some were also clockdoubled on the system bus, so those could either go under 5x for 200MHz to 300MHz, or over 5x for 366MHz-500MHz, skipping 333MHz (which could be achieved on a 33MHz bus with a 750L and its 10x multiplier, which is remapped onto the 2.5x multiplier of the 750).
Similarly, if one wants to pursue putting a 745 on a PB1400 166MHz card, you could go for a 350MHz model and set the multiplier to 10x to get the max clock speed possible of 333MHz.
System Profiler will likely report a false reading, assuming 2.5x33MHz, but any application like Gauge Pro or Metronome should show the correct 333MHz clockspeed.
However, with the availability of 750 based accelerators with backside cache, I'm not really interested in getting the 166MHz card to do this mod, as it would be in all ways inferior (using L2 cache on the slower, more congested system bus instead), and not doing anything new as those accelerators already provide a G3 for the 1400.
In more positive news, I was given a sample photo of the MPC745BPX350LE part from the supplier, and it does in fact not looked cooked like my others.
Kinda bummed the other ones are all likely fried, though I couldn't have known because of the lack of any reference pictures for these chips at the time.
Good question, I’m not sure.
Looks good, are you going for it (and can you be sure it’s not remarked)?
I have bought it, yeah.
As for remarking, ironically it's the mask and manufacture date/facility markings that look off, not the part number markings.
In any case, the gold markings on the die carrier package itself match all the 745s I've seen, so even in the case of a remark, it's unlikely to be anything other than a 745, so I'm not too worried about it.
This thread is fascinating. Didn't realize it got updated in 2024. I have the NewerTech 603e 183 MHz card, and am interested in what's going on here.
Hate to break it, but I've officially given up.
I've tried the final 745 a few times, including with 0.65mm balls (as I was having great difficulty getting it reballed with 0.76mm balls), but the behavior remained the same: The PowerBook turns on, but nobody's home.
No chime, no activity beyond the HDD powering up and idling, it just doesn't want to work.
Is the 745 any good?
I right now can't say for certain, because I have no hardware I'm willing to rip the CPU out of to put it in place of, but I want to stop prodding this board before something goes wrong from reflowing over and over, and @CC_333 rightfully wants the card back after all this time.
If I get some hardware to test with, that 745 will get tested, and if it works there, I'm just going to definitively call that this upgrade just isn't possible with the cards and CPUs available.
Sorry folks, I really wish we could have done the crazy upgrade on the Blackbird, but it just wasn't meant to be.
