Thank you for clearing that out! ????Each disk image file must be in a contiguous range of sectors on the SD card, in order for the disk emulation to work correctly, otherwise you'll see the warning about a non-contiguous file. This doesn't have anything to do with the file itself, but rather with how the file is stored on the card. Normally this “just works” without any special effort, but if you’ve repeatedly added and deleted files form the SD card, then they may become fragmented across different sections of the card. The easiest fix is to delete all the files on the SD card, and then copy them all back. Or reformat the SD card, and then replace the files. A defragmenting tool should also work, but the other methods are easier.
Sadly, I doubt it will ever be possible... The 512k has one internal floppy port and one external. Even if it's able to boot from external floppy drive, I don't even know if the hd20 could be plugged into the internal connector (never tested). But that's not the main issue here. The problem is when you plug (even a real) HD20 to the floppy port, you don't have access to the chained floppy drive until the HD20 init is loaded...... from the other floppy drive (which have to be directly plugged on the other port)! So unless wiring two cables (one from internal floppy port and one from external) and plug them into a new dual ports floppy emu (which doesn't exist of course), I don't see any any way to just plug a "floppy/HD20 emu" in the back of the machine and boot from that with no boot floppy (real or emulated) in the internal drive...The only major improvement I'd like to see is for the Floppy Emu to support emulating both a floppy drive and a hard drive (either Smartport on Apple II or HD20 on Mac) at the same time. Then I could 'bootstrap' my Mac 512 using HD20 "boot floppy" without needing to use an actual floppy.
I actually ran into this yesterday. I did as you said: reformatted the SD card, then copied the data back onto the card. I have mounted the SD card under Windows 10, OS X Tiger, and OS 9. I notice OS 9 adds a Resource Fork directory and Windows adds System Volume Information. I'm going to have to research if there is a way to disable the OSes from automatically creating these directories.Each disk image file must be in a contiguous range of sectors on the SD card, in order for the disk emulation to work correctly, otherwise you'll see the warning about a non-contiguous file. This doesn't have anything to do with the file itself, but rather with how the file is stored on the card. Normally this “just works” without any special effort, but if you’ve repeatedly added and deleted files form the SD card, then they may become fragmented across different sections of the card. The easiest fix is to delete all the files on the SD card, and then copy them all back. Or reformat the SD card, and then replace the files. A defragmenting tool should also work, but the other methods are easier.
Unless you get the ROM-inator II … it adds HD20 support. I use it with my IIcx, works great!Every mac between 1984 and 1996 at least can use Floppy mode, but for HD20 mode only 512k, plus, SE, Classic, Portable, IIci and IIsi are able to![]()
