Today I was fortunate enough to pick up a demonstration unit Portable in absolutely amazing condition from a physical standpoint. Literally, not even dirt in the 3 grooves of the ring that holds the trackball in place.
Given it is a pre-production demonstration unit, I assume it is the non-backlit model.
In typical Portable fashion, it didn't want to turn on. It would flicker like it wanted to and show a sad mac for less than half a second before power cycling endlessly, with the hard drive and floppy drive making repeated spin-up sounds (luckily no clicking was immediately noticeable).
I removed the main battery and replaced the 9V battery. Tried starting again. The display would stay on just long enough now to see the error codes appeared to be random.
Removed power at this point. It was actually still trying to spin the drive and power the display from the 9V alone, impressive (the 9V turned into an 8V in the span of 1 minute
). Removed the 9V as well. Turns out you are NOT supposed to try running the portable with the main battery removed. Oops. Only tried for a minute with the stock power adapter, hopefully nothing got burned up.
I know it definitely needs a new main battery... and probably another 9V since it pushed through the one I had just put in. As of today, what is the recommended battery rebuild/replacement method? Rebuild the original battery, or replace with an EXIT sign battery? Please feel free to drop links to sources (amazon, batteries plus, etc) of whatever battery you believe to be the best.
I expect that there is at best a 1% chance that the caps are still functioning within spec. At any rate, I'd like to replace the battery and if the Portable still can't run (which I fully expect it to fail), I will look into recapping.
Finally, time to identify what some of the cards are installed in the back of my portable. I'm guessing a 1mb RAM expansion board (to hopefully give me 2mb of RAM total), and the dialup modem board. Let me know what you think based off the photos:
Neat extra, Apple/Sony branded charger... not sure if normal or unique, but definitely different from my old 100 series charger I owned years ago:
