Yours doesn’t drop to under 700mAH in capacity though.
Yeah, that is true. EMMpathy is reporting the stock 1752 for them always, never changes.
I will test my AA packs on Battery Amnesia later today... currently running down my new "A" pack.
Batteryamnesia sees each of the 500 Series two packs as 50% each. If you plug a battery into the left bay, it should jump up to 100% according to it.
Yes, an hour and a half is what I get with mine and that's just normal use.Finally died at 88 minutes with the "A" size pack under Battery Amnesia. I would think that's a reasonable result?
So I’m back up to two batteries again. I bought a second-hand battery advertised as non-working but it had a good EMM board. It had uncorrectable errors so I changed the EEPROM with a new one while I had the board desoldered, then soldered it to my existing battery pack. It works great!Ah bugger - the one I repaired today has died. I fully charged it, then ran the laptop off it until it had discharged and it’s now disappeared again.
Yep, I’m impressed too!Performance is better than expected. I got 208 minutes out of BatteryAmnesia before it shut down. It’s curious how the graph flatlined at 50% discharge.
