Sonnet Encore ZIF G4 CPU Upgrade - G3 B&W jumper setting
This thread mentions something about it: "This is probably because those cards use PLDs/FPGAs to interface the processor to the older bus, and they apparently can't operate at 100MHz." Someone more knowledgable might have to chime in with what the reasoning was.
So they added the FPGA so it could be used in the Beige and the B&W/Yikes, it was not a technical limit of the machines themselves, but rather Sonnet didn't want to design two upgrades.
not so sure on this one, this may well be the case, but from what I recall reading many years ago, sonnet themselves claimed it was some sort of errata between the 7450/7455 CPU and the MPC106 itself that prevented them from operating the whole lot at 100Mhz
of course sonnet might of been BSing when they said this to cover their own failings, but at the same I can well belive there being unforseen compatibility issues, the Grackle chip was never officially released in a 100Mhz form to the wider market, I have never been able to find any datasheet on or the such like and all the 100Mhz parts I have seen have been XPC parts, ie that is to say not fully qualified
one card that would be interesting to experiment with here would be, is if I recall correctly the older versions of the Sonnet 7450/7455 700Mhz-1Ghz ZIF CPU's where compatible with the G3 beige *only* so I would guess those dont have whatever logic flips the socket connections around in the later versions that are both G3 beige and Blue and White compatible
but if one of those G3 beige only cards could be inserted into a G3 blue and white motherboard anyways on a test bench (where it dosent matter if its jutting half way out of the motherboard because its designed for a G3 beige actually) might be an interesting test in itself, just make sure to set the CPU PLL accordingly for a 100Mhz bus and see what it does!
I do know that in generally these ZIF's can be run at a 75Mhz bus, so there is a bit of wiggle room
also since I see this question get asked quite a bit, here is a pinout of the power connector on these ZIF's for anyone missing the original wiring loom that would of come with it
(although it would be good to get a 2nd source on that, if someone who does have a loom could indeed confirm or deny the pinout above)
and also here is a bus speed jumper setting guide for the G3 blue and white/Yikes!
Where there's a will, there's a way. There is definitely some oddity that Sonnet didn't feel was worth fixing (despite handicapping the faster B&W/Yikes with a 33% slower bus). Still glad they released this upgrade, although I went with the 750GX for my B&W back in the day (perfectly fine in OS X with Quartz Extreme).
Someone needs to experiment.
It's just the Sonnet 700MHz-1GHz upgrades are so rare and expensive that not many people are going to hack about one.
Were all the 700MHz Beige only, or were there later versions that were 'universal' and still 700MHz?
I think the 66MHz drop threw a lot of B&W G3/Yikes people off of buying it. I wish there were more floating about.
I remember a dual ZIF daystar adapter that popped up one time (some others probably remember it too) for a good grand. It had been... modified, if an unprofessional manner. Such a rare upgrade butchered. Rarity doesn't stop a fool.
