Macintosh SE FDHD MIDI playback help:
ringo
Hi, so recently i got my Macintosh to communicate with my good old mac man midi interface. The midi signals I can confirm that they are working, but there is no direct sound playback out of the Macintosh speaker. I know that most people just bought a interface like the Roland sc-7, but I was wondering if possible is there a sound driver for the Macintosh where I can have the sound playback live midi signals out of the internal Macintosh speakers without any sound interface?
You mean you're sending MIDI to the SE from a keyboard or other MIDI controller and want the Mac to play the notes? I don't know of any software that does that on a 68000 machine. Back in the day on those machines you recorded MIDI into a sequencer like MasterTracks Pro and then played it by sending it out to a synth or module. The Mac itself was never making any of the actual sound.
I gigged for a few years with my Mac SE on stage as the main sequencer.
I used Mastertrax Pro 4 software.
The Mac / Mastertrax did not create any sounds , its just a sequencer. Loads midi file into Masterax , plays midi file and sends the midi to the midi interface
Thats was it
Mastertrax had great midi editing , quantitize , program change , volume - It could take the entire memory dump from your synths with system exclusive - great memories - No internet back then , I had no manuals for mastertrax , just figured it out over the years
I remember there were some programs that acted like soft synths but they were to basic to be of any use
Thats was it
Sorry for late reply. You know. That's smart, I think gigging with a Macintosh not only brings some nostalgia to the audience, but also brings a uniqueness to your band. I always dreamed of getting tons of old 68k macs to line them up together on a stage to make one heck of a synth.
Do you have Quicktime Musical Instruments installed? I'm not sure which OS that would require.
I actually solved the problem, it was due to a bad midi cable. I don't believe I have quick time on my Macintosh SE running system 7.1
