I believe there is a PVR check that doesn't recognize the 750G, so it apparently defaults to some generic PPC 60x. At 800MHz (100MHz bus x 8) the PLL_CFG for 8x on the 750G is 10000 and it reports 300MHz, which agrees with the setting for 60x 1000. At 1.1GHz the 750G setting is 10101 and it reports 400MHz, where 60x is 1010. That's not conclusive but I think I see a pattern...
interesting sounds like its not recognising the last PLL bit properly, If I recall correctly of the patches offered in the Powerlogix Patcher is for to patch the system for correct PLL/frequency reporting, I take it you you have tried selecting that option? (but maybe out of the box its only patching for 7447/7447A/7448's and needs further patching for 750GX?)
I know its just a cosmetic thing, but im an "About this Mac" Junky, so would be sweet to see the "1Ghz G3" in all this glory
BTW one fun thing to do with one of your G3 cards and sawtooth or an MDD, is install 2GB of RAM, until now theres never been a system with a G3 that could take more then 1.5GB
BTW going back to your earlier test with the PPC750S CPU, was there any resistors/straps you had to change on the AGP CPU card, or where you able to just solder it in place of the previously removed G4 CPU? I have a number of PPC750S/PPC750L CPU's I have pulled from various systems I have G4 upgraded over the years (mainly Pismo's, but also a Clamshell iBook G3 and a slot loading iMac G3
) so I would like to try installing one onto a G4 CPU card
The nice on-chip L2 cache should help a lot on bus constrained systems. Also, the bus multiples go up to 20x so you could have a 1GHz G3 on a 50MHz bus.
yeah thats exactly why I was mentioning it
In that regard with your 750/7400 to 750GX interposer it would be fun to try one in a PowerBook G3 Kanga, another Orphaned mac, its pretty much a PowerBook 3400c with a G3 750 and backside L2 cache slapped onto it, and unlike every other G3 system from apple, its based on a pre-gossamer platform, its PSX+ and O'Hare, as such its also the only G3 system that apple never officially supported with Mac OS X or Mac OS 9.2.2 (although xpostfacto and OS9Helper works around that
a G4 7400 on a Kanga is another I would love to see someone try some day, just because then in theory it would be possible to run Leopard on one, imagine that!
as an aside does anyone have a picture of one of the 750FX/750GX PowerLogix CPU card for the PowerMac 7300-9600 machines? I have seen a few ZIF ones for G3 beige/G3 Blue and white etc, but I dont think I have actually seen any detailed pictures of one of the 7300-9600 750FX/750GX cards, I wonder if it would be possible to remanufacture those also
