I finally got around to replacing the SCSI2SD in my SE SuperDrive with a BlueSCSI v2 last week. I was initially hesitant because of not having any BlueSCSI experience, but the SCSI2SD starting to flake out changed my mind!
So, the installation physically, using the online instructions, worked very well for me. I made a custom install holder to keep the BlueSCSI in place where the HD usually sits. After a little troubleshooting, I found that the stock SE HD LED worked best with the “brightest” LED pads bridged per instructions. So far, so good.
Next was the not-so-easy part. I wanted to move a bunch of my System 6 stuff onto a new disk image to use with the SE. I used DiskJockey to create a new image…but then realized that these “.hda” images are not mountable normally by a Mac of any sort (that I can see). It took a lot of back and forth, new images, old images, using minivMac, etc, to pull off what was far simpler with the SCSI2SD. One awesome SCSI2SD feature was auto disk mounting over USB: I could hook the device to my G4, and magically the SD-based HD would pop up on the desktop. Copy files from the G4…and done. Even if I had just put the SD card into a reader on the G4, same thing. Incredibly easy. That’s one huge edge I think with how the SCSI2SD works. No emulators or multiple steps to get things back and forth.
I realize this is just inherently how the BlueSCSI works. My question then is: can it be made to work with .dmg images instead of these .hda things? Then I could at least mount the image on the G4 and copy files. Has anyone done this, or any chance someone could somehow implement it?
