Using Zip drive as HDD for Macintosh Plus
HI all. Have iomega zip driver 4.2 on zip with system 7.01. Have booted from a floppy and the zip appears on desktop OK but on restart from ZIP drive it starts to boot get splash with happy MAC for about 2 seconds and all looks good then crashes to black screen with error. Have tried on SE and it works also tried on second Plus MB same result, also tried a different zip disk and drive. Its at the I Have To fix this stage out of principle not necessarily need. Also tried setting up 6.08 on another zip disk same problem!!!
A joyous moment! Do you remember how you did it? Did you use FWB or something to downgrade the boot partition driver? Or did you use your PB1400? Or maybe boot on the external SCSI HD; then remove the System file from the Zip drive and then copy a new one back to bless it?
I think I used my PB1400 to back up the contents of your not-quite-yet-bootable Zip, then I reformatted the Zip disk using Apple HD SC Setup. So it uses Apple’s driver and appears like a SCSI hard drive to the Mac Plus.
@Fred1212
I am trying to use a zip 100 to boot a plus. It starts to boot but crashes at a sad mac with error 0F0063. Anyone come across this? thanks
So, I think we have a solution:
So, going back to your original issue. Not sure exactly what facilities you have. So, if you have a secondary SCSI drive, then it's fairly simple to copy everything you need from the Zip disk to the other SCSI drive, reformat with Apple HD SC Setup and then copy back. If you just have floppies, then it'd depend on how much space you have.
Another solution is if you have a 100MB USB Zip drive. You can then use HFS Utils on a Linux machine to copy everything from the Plus's Zip disk to Linux; then reformat the Zip disk on the Plus using HD SC Setup, then use HFS Utils to copy back.
Hi everyone thanks for all the info. Firstly I followed the process and initialised the zip disk with patched hd setup 7.53 then reloaded the system folder back onto disk. Didn't boot first try so I booted the Plus from an external floppy that had the iomega driver on it and I could see the zip on the desktop. Took the system folder out and put on desktop then back onto zip restarted and it booted. I had a iomega driver in the system folder on the Zip disk which now didn't load, so the zip drive is using the apple driver from the HD setup initialization. Excellent result, it now works. Cheers to all
Brilliant! And great to see you using Floppies! What OS did you use on the Floppy disk, and can you provide a screenshot of the system folder?
I have a 800k external and 6.08 on the disk. Unfortunately you need 7.5 or better to run the patched HD setup so I did this on a LC475
Hello! Can anyone help me set up an Iomega Zip drive as a HDD for my Macintosh Plus? I have pieced a few instructions together from my research on the web. This is the process I’m trying to get working:
  1. Make system disks of 6.0.7 or 6.0.8 (I have both).
  2. Create a start disk (I made one for 6.0.8)
  3. Make an Iomega Zip 4.2 installation disk (I have this)
  4. Insert the Zip 4.2 installation disk and drag the Iomega driver to the start disk
  5. Open the start disk and drag the driver to the system folder
  6. With Zip drive connected to the SCSI port, restart the Mac Plus with the start disk (you should notice the Iomega driver load at the bottom of the screen) —> ***I am stuck here, the driver appears at the bottom of the screen while booting up, but it has a giant X through it.
  7. Put a zip disk in the zip drive, the Mac will ask if you want to initialize it - agree to it
  8. Once complete it will mount
  9. Eject the start disk and insert the system tools disk
  10. Open system disk an click on system install and install system 6.0.8 to the Zip drive
  11. Drag the Iomega driver to the system folder on the zip disk system folder
  12. Restart the computer with only the zip disk drive connected and it should boot
As stated, I am stuck on step 6 above with the Iomega driver failing to load. Does anyone know why this is happening?
The Zip drive model I have is Z100P2 with a SCSI interface. I have seen some things on the internet about switching to ID 6 and making sure the end point is switched on. I do not have these switches on my Zip drive. Would this be an issue?
I also read this thread “Zip drive and Mac Plus”, but it doesn’t help me with my driver problem.
Thanks for your help!
- Jon
It should look like this
Unfortunately, that's a parallel port Zip drive. It looks like it has a SCSI port, but it's not really.
