II, IIx, IIcx and SE/30 GLUEs are identical. The video part of the SE/30 is done entirely in the 4 PALs that act like a PDS card to the rest of the system.My suggestion would be to target the IIcx GLUE first
All the better. The II and IIx don't have subtle difference due to the slightly weird memories? The nice thing about the IIcx is that in addition to the simplicity, it's bog-standard FPM memory and I believe works out-ot-the-box with the the IIsi's 32-bit clean memory. If the Iix and SE/30 have the exact same GLUE and can use the same well-known ROM (might need to disable some stuff if some hardware is missing at first), then they're also fine.II, IIx, IIcx and SE/30 GLUEs are identical. The video part of the SE/30 is done entirely in the 4 PALs that act like a PDS card to the rest of the system.
Nope, they fixed the memory issue externally in a PAL on the IIcx and SE/30.The II and IIx don't have subtle difference due to the slightly weird memories?
How does the mod look?I do have one of my Mac II boards modified in a similar fashion and it runs just fine with high >1MB RAM SIMMs.
@Callan Hmm, looking at the datasheets, replacing a 27C64 with a 27C512 seems like it would be slightly tricky, but doable. From the SE/30 schematic, pins 27 and 1 are tied high, which are A15 and A14 on the 27C512, so the ROM image would need to be written at offset 0xC000. Also, because pin 26 (A13 on the 27C512) appears to be floating (haven't checked on the HW yet, just looking at the schematic), it seems like it would be a good idea to write another copy at 0xE000, because A13's state is going to be indeterminate unless I stick a pulldown resistor on it. Actually, it would be easier to pull it up, just bridge it with its neighbor A14 on pin 27. Then I could just write a single copy of the ROM starting at 0xE000, though the end of the chip.Heya Obsolete. I have LOTS of 27C512's (256's too, but did I mention I have a lot of 512's?). Send me a message if you need a couple and I'll send them your way gratis.
I have 2764's too. I have pretty much any eprom you need bud (2516/2716 up). Byproduct of being a game tech for over 25 yrs. Let me know what size / speed you need and I'll send you a couple. I can program them for you too if you send me the bin.@Callan Hmm, looking at the datasheets, replacing a 27C64 with a 27C512 seems like it would be slightly tricky, but doable. From the SE/30 schematic, pins 27 and 1 are tied high, which are A15 and A14 on the 27C512, so the ROM image would need to be written at offset 0xC000. Also, because pin 26 (A13 on the 27C512) appears to be floating (haven't checked on the HW yet, just looking at the schematic), it seems like it would be a good idea to write another copy at 0xE000, because A13's state is going to be indeterminate unless I stick a pulldown resistor on it. Actually, it would be easier to pull it up, just bridge it with its neighbor A14 on pin 27. Then I could just write a single copy of the ROM starting at 0xE000, though the end of the chip.
Could someone please check my logic here?
You've got mail!I have 2764's too. I have pretty much any eprom you need bud (2516/2716 up). Byproduct of being a game tech for over 25 yrs. Let me know what size / speed you need and I'll send you a couple. I can program them for you too if you send me the bin.
Forgot about those but yes, the assumption is sound isn't a critical feature so can be ignored in a first draft. And it's one of the thing for which I did write a driver (for HDMI audio), so there's a path to an alternate solution to add sound later.The IIcx also has the ASC (344S0063-A), but I guess if you can live without a SWIM, you can live without sound too?
You're along the right lines I guess, since burning the VROM onto a 27C256 (without adjusting any offsets, etc.) does not work in my SE/30.@Callan Hmm, looking at the datasheets, replacing a 27C64 with a 27C512 seems like it would be slightly tricky, but doable. From the SE/30 schematic, pins 27 and 1 are tied high, which are A15 and A14 on the 27C512, so the ROM image would need to be written at offset 0xC000. Also, because pin 26 (A13 on the 27C512) appears to be floating (haven't checked on the HW yet, just looking at the schematic), it seems like it would be a good idea to write another copy at 0xE000, because A13's state is going to be indeterminate unless I stick a pulldown resistor on it. Actually, it would be easier to pull it up, just bridge it with its neighbor A14 on pin 27. Then I could just write a single copy of the ROM starting at 0xE000, though the end of the chip.
You can try 'bending away' the problematic address pin (so they are no longer in the socket/PCB) and soldering them using some patch wire to low instead of high (or the reverse). if the chip is toast anyway, it doesn't risk much, you just have to make sure you don't short anything.I have one more of these chips to experiment with, but I since they're write once, I guess the first one is junk.
Let's see, on a 27C256 you've got A14 tied high and A13 floating, so in theory you'd need two copies of the ROM, one at 0x4000 and one at 0x6000, to account for the indeterminate state of A13.You're along the right lines I guess, since burning the VROM onto a 27C256 (without adjusting any offsets, etc.) does not work in my SE/30.
True, if you were to bend away pins 26 and 27 (A13 and A14) and ground them, it should work.You can try 'bending away' the problematic address pin (so they are no longer in the socket/PCB) and soldering them using some patch wire to low instead of high (or the reverse). if the chip is toast anyway, it doesn't risk much, you just have to make sure you don't short anything.
I forgot about that project, very cool!Forgot about those but yes, the assumption is sound isn't a critical feature so can be ignored in a first draft. And it's one of the thing for which I did write a driver (for HDMI audio), so there's a path to an alternate solution to add sound later.
Well, I burned two more copies of the ROM, at these offsets, onto the chip I'd just incorrectly burned. Turns out you can write to the chip again, just not to previously burned sectors. So the chip now has three copies of the ROM - at 0x0000, 0x4000 and 0x6000 - and it works great, just verified.Let's see, on a 27C256 you've got A14 tied high and A13 floating, so in theory you'd need two copies of the ROM, one at 0x4000 and one at 0x6000, to account for the indeterminate state of A13.
Again, I'd like someone with some more experience to verify that my thinking here is correct.
Hooray!Well, I burned two more copies of the ROM, at these offsets, onto the chip I'd just incorrectly burned. Turns out you can write to the chip again, just not to previously burned sectors. So the chip now has three copies of the ROM - at 0x0000, 0x4000 and 0x6000 - and it works great, just verified.
Yes, awesome!Hooray!![]()
Could this cause any issues, even with the two copies of the ROM?pin 26 (A13 on the 27C512) appears to be floating
Yeah, but just by touching it with a meter, you may have changed its stateRight, so looking with a multimeter, A13 (pin 26) is at 0.5V with my SE/30 powered on. Therefore it's accessing the code starting at 0x4000, I take it.
Is this quantum computing then?Yeah, but just by touching it with a meter, you may have changed its state
Doesn't matter though, because with copies at both possible offsets, you're covered.
