Does anyone know the pin-out?
The center pin actually has 3 parts (much like a headphone jack), and the cable has the shield (which is the minus), and then 3 other leads corresponding with the inner 3-part pin.
The powersupply I have started smoking and smelling when I put it in the poweroutlet, luckily not connected to the Duo at the time.
Last time I used the Duo, it worked normaly up till I just disconnected the power supply.
As it is a 24VDC 1.04A rated supply, and I have many 24DC powersupplies, I would like to use those for the Duo, just not sure of the pin-out, and not sure how the charging circuit works (thinking of the weird way a Mac Portable works).
Any tips? I'd rather avoid blowing up the Duo!
