Bought an second hand PowerBook Duo 230 with a smelly Power Supply, any idea which part is this and is this still available or is there an replacement ,
Most caps available except I couldnt locate the big cap at the correct height or diameter on mouser / digikey
Thats a rifa / safety cap. Thats what they do when old. They blow and smell bad. Never experienced one personally thank god will have to check the value..
Macdat.net might have info for rifa. Will see if i can find any info as well
