Wait, is that a real book?
Lmao perfect for the ADD brain!!! I've always wanted to achieve legendary status with Mac SCSI and now I can!! I don't know whether to call you Mr. Fahrenheit or Mr. Warmth
Lol I appreaciate a little roast! Snowing at my house today; I don't know if I should just burn my cash for heat or turn on the furnace, will probably cost the sameYou’re Canadian, so the book is $49.95. Mr Fahrenheit is fine. I’m 200 degrees, which is more than “warm”.![]()
The same page also says 'These switchboxes may not look like the one pictured, but they are very similar and do the exact same thing. All units have a 1-year warranty.'
That is hilarious.
I still am unaware of the risks involved, so in the spirit of ingorance and negligance I will continue to guinea pig this switch. I do have a cpl battery bombed boards and a hot air rework station... Call me stupid but I can't see this destroying my mobos or devices. Being as they do the 'exact same thing' internally, I don't see the difference. I also do not run an HDD of any kind in my Macs, I feel I'd be more weary if I was using an old SCSI HDD. However if I show up complaining that it's ruining my devices then I don't expect any sympathy!! lolThe same page also says 'These switchboxes may not look like the one pictured, but they are very similar and do the exact same thing. All units have a 1-year warranty.'
Could be that what they are selling is different to what you have. I agree with the others, I wouldn't use it with SCSI devices.
The list of risks for this is on page 42 of my book. You’ll have to order it to find out.I still am unaware of the risks involved, so in the spirit of ingorance and negligance I will continue to guinea pig this switch. I do have a cpl battery bombed boards and a hot air rework station... Call me stupid but I can't see this destroying my mobos or devices. Being as they do the 'exact same thing' internally, I don't see the difference. I also do not run an HDD of any kind in my Macs, I feel I'd be more weary if I was using an old SCSI HDD. However if I show up complaining that it's ruining my devices then I don't expect any sympathy!! lol
That’s a bit more comforting, but I’d still be a bit concerned looking at the rats nest of cables in there.OKAY, warn me thrice AND tell me the risks I guess this is not an experiment and just an exercise in Tom foolery to keep using it blindly! Let's see what's inside. View attachment 64289
So here we can confirm it is a pin to pin configuration, 0 resistance between pins when set to the 10ohm scale. I checked all the pins on both settings to be extra sure. I also checked to see if there's any connection bleeding through to the inactive port and I could not detect a connection on any pins.
I believe this confirms that it's safe to use, but I will use my discretion next time before jumping in with both feet!
Yes indeed!Thoughts to ponder.
Let's keep it realistic Forrest.You may not be so lucky in 3 years at 1:00 am, when you switch with all devices powered up and see a small puff of smoke emerge from your drive…
The book is done. Front and back cover, and one page inside. $19.99Please add me to the list for the first printing of the @MrFahrenheit book!
