Techknight is right... those quantums are pretty much garbage now.. I've been able to save a bunch of other manufacturers hard drives but not the quantum scsi's... and that logic board needs to be cleaned and recapped... try to get the gunk off before it does anymore damage to the board. I use a toothbrush and 90% rubbing alcohol in the bath tub... before that I first I remove the SMD caps by squishing them opposite of the solder joints so it makes it easier to rock them back and fourth.. You have to be REALLY CAREFUL when you do this not to pull up and pull off the pads. If you haven't done it before just doing the rock back and forth method is the best while pressing slightly against the board so your not pulling up.. and when one breaks free keep pressing against the board till both leads break free.. DON'T PULL IT. I let it sort of fall off in my fingers on the board before I take it off the board. Then I clean with a q-tip and 90% alcohol 1st to get the initial goo off around where the caps were.. Finally I do the bath in the tub with 90 % rubbing alcohol. I scrub with the toothbrush in between chips and where the caps were.. after scrubbing is done I rinse down the front and back with the 90% rubbing alcohol bottle to rinse off any debris. I shake it in the tub to get off excess alcohol and put it in front of a small space heater with fan in my bathroom to dry it off... (a hair dryer would work better I'm sure). The alcohol dries pretty fast... also be sure to ventilate where you are doing this.. don't inhale those rubbing alcohol fumes.
