Yes, indeed.with the original 16,6Mhz oscillator back in and the 32MB RAM card, was it stable?
this is your 40 Mhz osci( top right) ? I have not looked up its' PDF specifics, maybe it is not fully compatible? soldering ok?
I backed off on the overclock as it wasn’t stable running MacBench 3. I have another 33MHz processor card and I tried installing the oscillator in this one to see if it would fare better, but with the mod it weirdly stopped working with my 32MB RAM card (giving death chimes).
Well, you might have more luck than me?Ok, I just received the oscillator but going to hold off on installing it.
I agree, it could be a heat issue.I still haven't ordered them myself - now I am a bit hesitant to try... If jmacz succeeds then I might.
It does seem to me like it may be a heat issue though - AFAIK people are usually able to successfully overclock the desktop 040 chips from 33 to 40MHz without trouble, especially since they only crash under load.
So I installed the oscillator. System comes up and TattleTech identifies the CPU at 40Mhz. Now working on getting MacBench installed.
An update after poking at this a bit more. My second modded processor card apparently death chimes with either my 32MB RAM card, or my 8MB RAM card, but works fine with my 16MB card. With the 16MB card, it is totally stable, gets through MacBench.I backed off on the overclock as it wasn’t stable running MacBench 3. I have another 33MHz processor card and I tried installing the oscillator in this one to see if it would fare better, but with the mod it weirdly stopped working with my 32MB RAM card (giving death chimes).
Does your 32MB RAM card have 60 or 70ns chips?so today I made the last mod to my black coffee edition 540c, installed an extended 32MB RAM card and a little CPU boost with a new 20 MHZ oscillator.
CPU daughterboard out, RAM card out..new 20 Mhz quarz next to the old 16,6 Mhz oscillator.
View attachment 60675 View attachment 60674
old quarz desoldered, new in.
old 33 Mhz CPU, 12 MB RAM
new 40 Mhz, 36 MB RAM
View attachment 60672 View attachment 60673
doesnt make a HUGE CPU difference but my Indiana Jones fate of Atlantis is now running much better..
