I'm trying to set up my PB1400 running OS 9.0 to work with a Midiman Bi-Port MIDI interface, which has drivers for OMS 2.3.8. However, the 1400 has the switching modem/printer single serial port on the rear, and OMS insists on automatically searching for interfaces rather than allowing the user to define it. Predictably, OMS can't find anything attached to the serial port. I have also tested this with a Roland SD-20 and a Korg AG-10, both of which have appropriate drivers, and tried different cables all around.
I found an ancient AppleFritter thread about this issue with the 1400 and other Powerbooks which has some clues, specifically using the files reset-serial-port-2.1.sit.hqx or serialsetter-1.0.sit.hqx to force any part of the system using the serial port to give up control and allow OMS to take over. But, the only place these files seem to possibly exist is an Arizona MUG FTP which requires a non-anonymous login, with old links found here which is itself a mirror of an ancient EarthLink personal page. Does anyone know anywhere else to find those files? They look like something that would have been floating around on old MUG freeware disks, maybe?
It also looks like there might be a hardware hack to force the Powerbook serial port to correctly signal an Opcode Studio 3 MIDI interface, but there's no way to know if that's specific to the Studio 3 or if it works more generally with other MIDI interfaces or serial devices. Opcode states on their FAQ of the time that their later MIDI interfaces don't need that, so it may well just be a design fault in the Studio 3. I'd rather not have to try to buy yet another vintage MIDI device with the hope that it will work with my 1400 specifically before trying a software solution, if those old utilities can be found.
Anyone have any experience or familiarity with these issues? There was a thread here last year that mentions it but no conclusions were found.
