Help for a nubus Radius PrecisionColor Pro 24X ROM/firmware upgrade
I just bought this card on eBay. (pictured) I was curious if anybody could tell me if it was a 24XK or a Pro 24XK? Also, what is the purpose of the jumper? Thanks so much!
I think that is a 24XP to be honest. I'll double check.
Edit - yup, it is a Radius PrecisionColor 24XP. It has 1.5MB of VRAM and does up to 832x624 resolution.
The jumper isn't useful for end users. It isn't documented, but it is connected to a pin on the EEPROM that doesn't do anything. It is probably from development, or an option for things they never did, such as larger ROMs.
Hello Phipli, Thanks for your reply. I am humbled by the span of your knowledge, as you have weighed in on many of my questions. But I am confused by some conflicting info I am seeing. 1. in the thread (linked below) a card identical to the one I have is identified as a Pro 24X. 2. If it is a 24XP, shouldn't it support higher resolutions than 832x624 at 24bit? Gamba's site suggests. Clipping attached... not sure what the solid lines mean.
I think you're misreading the table? Your card is the Pro version, and there is an error on the non Pro row.
All of these cards use the same PCB and look absolutely identical, but with a different grade RAMDAC (big chip near the video out port) and amounts of VRAM. The board colours don't imply the card model.
Yours has a 66MHz RAMDAC chip which isn't rated fast enough to do 1024x768 or 1152x870. I haven't looked the VRAM chips up today but only one of the board models was fitted with the 66MHz RAMDAC, and that was the 24XP (and 24XP Pro which is basically identical), which is a 1.5MB board. I've previously done a load of work on these cards. My dad has a 24XP like yours. But blue.
Thanks so much. Kind of disappointing news... I was/am not sophisticated enough to know about RAMDAC chips. I thought it would be a 24 bit card up to 1024 or even 1152. I paid $130... probably too much. I really wanted to drive at least 1024 on my M2494 Multiple Scan 17 Trinitron. I thought it would be more like this Radius card in my other computer... Quadra 700 (pictured)... but that appears now to be a superior card. THANKS!
That card (24X) is a very good card.
They're both as fast as each other and 832x624 is quite a good resolution. The 24XP is still a nice card and given its speed and that it is an accelerated 24bit card, I don't think you really overpaid compared to some other recent listings.
If you get adventurous, you could make a 24AC ROM (about $2) using a ROM programmer (about $40) for your Quadra 700 card and swap it in. It would then be possible to run it using Apple's version of the drivers, and it would also work accelerated alongside a PPC 601 Upgrade card. With the 24x v2.0 ROM it works with the PPC cards, but not accelerated.
Very Interesting! Thanks for your information. :)
Oh interesting, I didn't know the Radius drivers wouldn't accelerate it. If I get my 601 card working again I'll give that a try on my 24X.
I'm not sure, there might be two versions of the card? An Apple and a Radius 24AC? LEM says there is, but LEM is often wrong, and I have never found a 24AC ROM that isn't from an Apple sold card. Plus the "Apple" cards have a Radius copyright and a Radius PCB.
Basically, that could be true, but it isn't quite what I meant. I meant the 24AC ROM I have a copy of uses an Apple provided driver. Probably still written by Radius.
True. There is no Radius PrecisionColor 24AC listed anywhere on Radius web page or any price list anywhere advertised. It was just a mistaken by Apple 24AC card which was made by Radius, only a back label identified it as Apple Display Card 24AC, see picture, front and back:
Where is this info from? For System 7.5 and Powermac compatibility Radius recommended Dynamic Desktop version 3.3 or later, QuickColor 3.3 or later, and ROM 2.0
Personal testing with about 30 tests of different cards, bit depths processors and OS versions.
ROM version 2.0 works with PPC, in that it doesn't crash, but it runs at the same speed as the 24AC does /without/ drivers. This means it is unaccelerated.
View attachment 62389 View attachment 62390
I was using version 2.62 of the Control Panel it seems. I'll try a newer version and see if acceleration works with V2.0 ROMs and PPC.
I also wonder if there's any difference in performance with the 24AC v. 24X ROM on PPC assuming acceleration works. That is, did the acceleration drivers diverge between what shipped in the OS versus Radius?
They were identical under 68k, so I suspect not.
I'm confusing myself because I just booted my IIci with my 24XK, forgetting that it is flashed with the 24AC ROM :ROFLMAO:
QuickColor didn't recognise it because it is an "Apple" card. Apparently.
I have my jumper mod on the card so I'll switch it back over when I power down next.
@slomacuser
You're right :) it is accelerated with 3.3. see results for all of my tests in my IIci below.
They're basically the same (OS version does make a difference, with OS8.5 being the fastest - don't ask why my IIci has 8.5 installed, I got carried away one day).
@lemketron
I have a couple of cheeky questions that I really hope you don't mind my asking. I didn't want to hijack the other thread, and realise many years have passed. But...
1 - Do you happen to know the purpose of the resistor straps I've circled as "1" in the following photo? They do seem to change between the lower end cards and the high end cards. Are they to do with VRAM organisation? Or something else?
2 - The highlighted jumper (marked "2")seems to connect and disconnect one of the pins on the ROM to the left most ASIC. The pin is either a write enable pin, or an address pin depending on what size ROM you have fitted (I've been fitting a larger ROM and rewiring this jumper slightly so I can manually bank the ROM between say, the PrecisionColor 24X and 24AC ROM, so I can experiment with the Apple driver or the Radius driver (they're the same speed, I'm sure you knew!)), but I was wondering what it was originally for.
3 - What... cough... are your thoughts on overclocking the Bt473? Or the second source part from Analog Devices? Did you find that an 80MHz part would happily run at 100MHz?
It would be nice to open up some higher resolutions at lower bit depths on some of the lower end cards if the RAMDAC is happy to overclock. Although I think I saw someone having issues where it looked like the cards with less VRAM had issues even if you had enough VRAM for a resolution + colour depth, you'd end up with VRAM being written to twice due to the chips responding to writes to higher addresses being generated by the ROM from a card with more VRAM. I assume because it was using the higher ranges of the lower order chips first, rather than filling all chips equally. It would be a lot of soldering to replace the VRAM!
Three additional interesting things of note:
  • I suspect the miroPRISMA 1152GX is also the same card. I've never seen one, but it runs basically the same ROM @ version 2.01. It follows the larger list of resolutions in the Radius card.
  • The last miro software, last QuickColor, and the last 24AC extension all load some extra PowerPC bits at init. I guess given the test results that doesn't make any real difference for speed, more for compatibility. If I had to guess, it's loading patched routines for the PowerPC copy of QuickDraw, as the older extension only patched the 68k copy. The driver code itself seems likely to be entirely 68k.
    • I would be willing to bet the card is faster on 8.6 because of the improved 68k emulator. I wonder if simply running Speed Doubler actually makes the card faster everywhere else.
  • It seems likely changing the HW ID on the Radius card's ROM from 1034 to 43 would make it compatible with the 24AC extension, if you don't want to use QuickColor.
For all the stuff ROMs we've posted, I think I might have forgotten to put the Apple 24AC 1.1 ROM on the forum. I'll sort through them and put them on my website at some point to have them all in a single place.
This ROM works with the Apple driver, not the Radius one, and has better integration with the Monitors control panel.
It is accelerated for both 68k and PPC. It supports resolutions up to 1152x870. The hardware is identical to the PrecisionColor 24X, but the display modes are slightly more targeted at Apple monitors. Performance is identical to the 24X.
Find attached the ROM and the drivers. Have fun.
