Through a lucky Yahoo Auctions Japan find, I've got my mitts on one of the most competent video cards for the SE/30 (and IIsi).
Resolution support is extensive, it supports resolution changes without reboot, respects sense lines, and goes up to 1152x870 at 24 bit or 1280x1024 at 8 bit. This is also quite possibly the only video card for 030 PDS machines that features acceleration. It helps a lot - even an CPU-accelerated SE/30 crawls trying to push pixels at 24 bit. As a dumb framebuffer, it is just slightly slower than the micron, but with acceleration on the GrandVimage is far faster at QuickDraw, especially at higher bit depths/resolution.
It came with a mystery bracket along with a bracket to mount the rear bracket in an IIsi - not quite sure what the mystery bracket fits. Maybe also for the IIsi. I've attached highres pics and more fun info.
- Manual, google translated (better than nothing)
- MacBench 3.0 comparison runs between both acceleration and no acceleration at 1152x870 24bit
- It is clear which functions have acceleration and which don't
- MacBench 3.0 comparison between Micron Color 30HR and GrandVimage at 640x480 8bit
- Color and res support tables
- VDR4 A21 V1.1.1 ROM Dump
- IMPORTANT: This was performed from Mac OS and is ideal for reverse engineering, but may require transformations (inversions, etc) before writing to a ROM chip.
- GrandVimage v1.4.1b2 control panel
