Never thought I'd see the day! (Studio Display 15-inch flat panel Rev A)
They are really really cool! Sadly they only work decently with PPC macs. Be careful with the stand, the plastic bits holding the main spring inside snapped on mine, and it‘s extremely difficult to repair!
This one seems to be playing nice with a Performa 475!
And yes – this one had the snapped spring holder. Some superglue is doing a fine job for now; if it breaks again though, my plan is to epoxy the spring end to the stand neck.
There's one on sale in Switzerland for CHF 150.—.
I was thinking about buying it so that I would have a DA-15 plus on an LCD screen but since I already have a Rev. 2 and the colour doesn't really match anything, the price was not at all compelling. Also LCD screens from that era are starting to suffer in quality.
That and the fact that the seller has stopped replying to my questions.
I was gonna say. the stand engineering is basically a guillotine for the mounts at this point. Unfortunate.
That is super cool - congrats! A school library where I used to work had one of these on a mostly-unused desk in the back of the staff area, and it bums me out that I never made an attempt to claim it. Glad that this one found a loving home!
Huxley
I can't believe I'm the proud owner of this beauty!
I love the Original 15" Studio Display, especially the color scheme! In some alternate universe we'd have translucent black and dark blue 2nd generation Power Macintosh G3s. ("Black & Blue G3" instead of "Blue & White G3")
In mine the pneumatic cylinder that is supposed let you adjust the height is kaput, same with yours or will it hold its position if you raise it?
I have one of these!
I don't have the fancy stand, though, but rather a simple fold out stand that lets the display sit easel-style, not unlike the later Studio displays that came with the G4s. I had always kind of wished I could have the fancy stand, but if it's so fragile and prone to breakage, maybe I'm better off without it?
c
The „fancy“ stand of the second (VGA) revision might be slightly better; at least mine it didn‘t break yet.. So I use the stand of my (dead) rev.2 on my working rev.1 (with broken spring clip). Works fine but the colours don‘t match 😅
I don't have the fancy stand, though, but rather a simple fold out stand that lets the display sit easel-style...
Funny - I wish I had the fold-out stand! Is it the right color for the Rev A? I've never seen that, even in photos. Anyway, grass is greener, I suppose :)
From reading online, it sounds like the neck plastic was a particular problem with the Rev A models. The plastic in mine had only partly broken off; the bits holding the spring vertically/parallel to the main line of the stand were there, but the parts that kept it from falling off those horizontally/perpendicular had broken. Since they weren't really weight-bearing, I tried super glue, and it seems to be holding up fine. If I need to do more serious work, I'm planning on following this guide, which uses epoxy to bind the metal spring directly to the neck plastic:
I'm also happy to report that despite officially "requiring" a PowerPC, I've had it working without issue on an LC 475 and a Quadra 700.
Yeah, I guess so!
I used mine on my then-recently acquired Quadra 840av, and it seemed to work fine. I didn't know at the time that it "required" a Power Mac, so I wasn't surprised at all when it worked.
c
The driver software bundled with it requires a PPC Mac. I have minor issues with it and the internal graphics card of my Quadra 700 (green tint, not able to set a resolution other than 640x480) but these could be resolved with the right system extensions.. Sometimes, the earlier AppleVision software complains about incompatibility on startup. Actually, the rev2 works better with 68k Macs!
Yes, I have those issues too with the Quadra 700 – green tint, only 640x480. Do you know what system extensions resolve them? I tried Basic Color Monitor, but that doesn't seem to have changed anything.
Umh.. That was some time ago, I would need to check again. But the Basic Color Monitor would have been my first suggestion…
Just saw this thread. Yours is in far better condition than mine, although we have "matching" stuck pixels.
Looks like I'll be fixing my stand with the guide Tweedy linked.
I have the Rev. B VGA port, B&W one. I did try to get it to work with an adapter on my IIfx, but it appears no-go.
I would love one of these! Unfortunately I have only seen a very slim handful for sale here in the UK, all in bad condition and at very high prices. The dream scenario would be to get rid of my B&W Studio CRT and replace it with a B&W Studio TFT.
Side note: the reintroduction of the Studio Display moniker has made it quite a lot harder to keep an eye out for these things.
