I have a socketed 50MHz 68030 Daystar PowerCache accelerator in one of my SE/30's, which uses the Power Central control panel to enable caches. In the documentation it mentions that Enhanced Power Math can be enabled by holding down the OPTION & COMMAND keys while clicking the PowerMath switch in the control panel. I confirmed this works because that results in an underline beneath PowerMath. (Enhanced PowerMath makes FPU performance even better.) Being curious, I held down OPT & CMD while clicking the PowerCache switch in the same control panel. This is not documented in the manual. A little black dot appears in the bottom left corner when you do that, as marked by the arrow cursor in the following screenshot:
My question is, what does that little black dot in the bottom left corner of the Power Central control panel signify?
Thanks.
Thanks.
