Radius PrecisionColor 8 ROM 2.0
jmacz
68020
Anyone have a working image of the v2 ROM for a Radius PrecisionColor 8?
I found this one on the forum but it's not working for me after writing to a 27C256 EEPROM (verified it as well after write):
My card has the 1.0 ROM and it works but for whatever reason, I'm unable to see a 1024x768 option when connecting it to a VGA LCD that supports 1024x768 at both 60/75Hz (Dell E153Pc). I see 1152x864 (which the LCD can't drive) and 640x480 works. I have a 10switch VGA to DB15 adapter and have tried pretty much all the combinations... Mode 1 (composite sync), Mode 2 (composite sync), Mode 3 (sync on v), Mode 4 (sync on h), and Mode 6 (sync on green) all don't work with the DELL. Mode 5 (separate sync) seems to work but when I use the switch combinations for various resolutions on mode 5, I'm only seeing 640x480 and 1152x864. So wanted to try a newer ROM.
Any help appreciated.
Do you mean PrecisionColor 8xj? Do you have a photo of your card?
Its my rip, I only made it a few weeks back. The card works fine.
What chip did you use to write it to?
The card is a Radius PrecisionColor 8... don't see an XJ on the label. Wrote it to a 27C256 70ns EEPROM. Here's some pictures.
Ok yeah, they are two different cards. The standard 8 (non XJ) seems to be an 8 bit card that only supports 640x480 and 1152x870. Couldn’t find anything else online. Not sure if it’s accelerated or not. That explains why the ROM didn’t work.
Yeah, you have an older card with more in common with the PrecisionColor 8-24 than the later 7" cards.
