What's the difference between the various Radius 24 cards?
So, the question -- is my "red" card really a 24X?
I believe so. It has the characteristics of a 24X - 110MHz RAMDAC and 3MB of VRAM.
The green card is the first I've seen like that. Most of the later Radius cards look like your red card - the silk screen is identical between all sorts of cards and the only differences are the component choices, and sometimes the colour (I think they just made them all Red later).
There is a third design of 7" card - with the ROM in the top left corner. My 8jx is a variant of that design, but has only 4 VRAM chips because it is an 8bit card.
Curiously, the "blue" card layout is pretty much identical to the "red" card, apart from what appears to be a faster RAMDAC on the "red" card
RAMDAC speed and amount of VRAM. The blue card has 128k chips, so only has 1.5MB, instead of the 3MB on your Red 24X.
I was leaning that way... I knew about the RAMDAC, had missed the total VRAM. I guess I need to see if the "red" card will come to life. I sense some tinker-time coming this weekend. 😊
Here's my green PrecisionColor 24X, sporting the same ROM version as @mg.man's red (v2.0 -066-03-A) and the same ramdac. Mine has 24X silkscreened, 3mb VRAM (42C8255DJ x12). Looks like the reds are a slightly newer layout, as they have 'rev B' under the assembly number and (c) 1993 whereas green's have 'rev A' and (c) 1992.
Interestingly one of the custom chips has a different copyright year too. They made some changes in the silicon it seems.
I feel like this thread and the ROM request thread could be combined. They look like they're starting to converge with all the ROM coverage. :)
Nice work, by the way, @Phipli , it's fascinating to see all the different ROM versions working.
Resurrecting this thread to ask what difference does the FW revs 1.1 and 2.0 make on the Radius/Apple display card 24AC. If there is a significant difference, is there any way to obtain a programmed chip with the FW on it? I have a 24AC with Rev. 1.1
Looking through everything I can find, I'm not sure that there is a v2.0 for the Apple Display Card 24AC... have you seen one?
The v1.1 ROM from the Apple card already supports PPC, which was the big thing about the v2.0 ROM for the other 24X series cards.
Hey Phipli,
no sincerely I do not recall seeing one, at this point I could imagine that rom 1.1 of the Apple card could very well be a Radius 2.0, since all 24AC apple cards have the highest specs for the 24 cards- 3mb and 110mhz ramdac.
this info alone could be extremely interesting !
Hey Phipli,
My experiments say the Apple 1.1 ROM works in the 24XK and 24X, and is the best ROM for them (I haven't tried the Radius 24AC yet because I don't have a copy on hand).
The 24AC's 68k performance is basically the same as the other cards... but... the PPC acceleration works properly!
Using the 24AC ROM in my 24XK on a PPC makes my 24XK do 24 bit as fast as it does 16bit with its own ROM!
Conclusion : we all need to put 24AC ROMs in our 24X and 24XK cards!
@Phipli: Seems like you could have all the answers!
I have an PrecisionColor 24Xk Series card (632-0187-03 Rev. B2), with 3MB VRAM, 80 MHz DAC, the ROM label says 295-0070-03-REVA V2.0. I'm planning on using in my Quadra 700 with a PPC card.
If I understand correctly the best performance, I can get it's using the AC ROM, right? Can you share this ROM? I haven't seen it shared anywhere.
Note: When trying to read my ROM the program complained about pin 27, eventhough I was able to read it.
  • 295-0070-03-REVA V2.0.bin
If I remember right, in the ROM thread we decided the Radius ROM (@2.0) should perform the same as the AC ROM with the latest Radius extensions installed on PPC. So you should be fine.
So can someone identify this Card ? For me thanks
I read the topic but not sure which model (it looks looking at the date an early model?)
