Acquired a Performa 6200
Greetings,
I've recently acquired a Performa 6200. Quite a tidy case you might agree; it was smaller than I expected from the photos! I plan to install Mac OS 7.6 or perhaps just explore whatever is currently on the drive once I've her serviceable.
She definitely boots because when I power her on I hear the boot chime and a flurry of HDD activity, which pleaseth me.
But two questions:
- How would I attach a display? I haven't any Apple displays that use a DB15 connector. Would a DB15 to VGA connector suffice, or would I be best acquiring an older ATI card to drive VGA as other threads have suggested?
- I removed the battery because I heard they have a tendency to leak and corrode the MB. Luckily this hasn't happened. Where would I acquire another with reasonable postage costs to the UK?
Thanks
CM
The adapter is your best and only choice :) the 6200 doesn't have a PCI slot for an ATI or similar card.
With a 6200, your best bet is to use a little battery box with three AAA batteries or AAA batteries, but don't leave it in there in case they leak. Another option is to just run without a battery, which works in most macs (but not all).
The 6200 has an unusual "square" 4.5v battery that isn't the same as the usual mac battery. Sadly they are no longer made.
The three battery version here, but you need to add a connector, possibly from the original battery, which of course you didn't throw out :)
I have NiMHs in my 640 CD. The voltage is lower but it doesn't seem to care. They can leak but not nearly as often or as much as alkalines.
NiMH cells will only leak if you leave them in for 20 years. Alkaline will get you in a couple years at most usually.
Fortunately I didn't (was a curiosity seeing something marked 'Made in USA' inside a computer likely made in Ireland), so will grab one of those battery boxes and splice it together.
Also ordered a DB15 to VGA cable, will see how it goes. Skipped over some fancier ones with DIP switches, might come to regret that, but can grab one next month if there's no joy with this one.
Probably should have got a dip switch one, but you'll probably be OK.
Was not aware those little cube batteries were also prone to leak. Better open up my 6200 when I get a chance and verify it’s still okay.
Yeah they're alkaline batteries inside... The plastic case will hold in the leakage for a while, but it gets out eventually.
Good to see I've less to worry about regarding PowerPC Macs. I suppose Apple were more open to commodity hardware at this time.
Still awaiting the delivery of the adaptor. Will be interesting to see what, if anything, was left on this Mac and uncover its purpose in its past life.
(@cheesestraws thanks, the goose is safe enough provided you don't approach suddenly and bring a few loaves)
Oooh I like very short cables like that.. I’ve put one in my basket for later!
Outta interest what kind of LCD screen are you trying to use it with? I have found some just reaaaaallly don’t like signals from older macs, even with configurable adapters.
@Durosity I tried it with an older Dell 4:3 19" monitor, I don't have it with me to check the exact model number. The oldest system I've had that monitor work with was a Windows 98 box rocking a Nvidia TNT2. The other monitor I tried was a much newer 23" widescreen monitor (also Dell) mostly for giggles, it didn't work either.
@joshc If you're willing to part with one that has those microswitches on it, seems like it is worth acquiring to try. Will PM thanks.
I plan to get a CRT for it, in a superstitious hope those will have fewer problems even if the CRT isn't Apple made.
