Was the chip reballed before being installed? These chips (all PPC chips, not just the 740s) have these weird not-quite-solder 0.89MM balls applied, which I have yet to figure out how to actually make solder correctly. Whenever I attempt to, they just don't make proper contact with the pads. I've tried pre-tinning the pads before soldering, and that doesn't help either. I've given up at this point, and whenever I get chips with those original balls on them, I just remove them all and reball it with standard solder balls, which works every time.
