How do I safely remove heatsink on a Apple nVidia GeForce4 TI4600 128MB card?
Hi everyone,
I just picked up a Apple Power Mac G4 (FW 800) with a dead PSU for parts for $50 on facebook, came with a 23" Apple Cinema HD display as well, was worth the drive I think. I grabbed it for parts for my G4 Mirror Drive Door 2003. It had the Apple nVidia GeForce4 TI4600 128MB video card as well as a dual 1.42GHz Processor that I'm going to put in my MDD 2003 to make a nice (and possibly the fastest G4) OS 9 bootable machine with original Apple Parts.
I'd like to remove the heat sink off the nVidia card to remove and reapply fresh thermal paste since its about 20 years old now. The heatsink is attached to the card with 2 plastic clips. What's the best way to remove these clips without breaking them so I can remove the heatsink and then reattach the heatsink?
It's just plastic pegs. I probably could squeeze with some needle noise pliers and push them out, but I'm curious if there's a safer way. I'd hate to crush the pegs and not be able to reuse them and have no pressure of the heatsink against the GPU
(different variant of the card) but seems like a squeeze is all I need, hopefully I don't ruin the pegs so I can reuse them. Wish me luck!
The heatsink on this specific model of card is glued on. Be very careful. You will struggle to put the heatsink back on properly once you have removed it due to the use-once clips and the thick resin/glue used as thermal compound. Even if you get the heatsink off without wrecking the GPU die you will struggle to get the compound off the heatsink. I got the heatsink off my 4600 Ti by dripping isopropyl alcohol onto it for about two hours.
That said, perhaps your heatsink will magically just pop off. Brittle thermal compounds are always a fun surprise after twenty years...
My advice is to forget about the original heatsink altogether because it is terrible and noisy. There are plenty of third-party aftermarket coolers for this model floating around. I recommend you grab one and enjoy a quieter card with better performance.
I chickened out with the pliers and removing those plastic clips. Wonder how good the original thermal paste still is at cooling. Could you send me a example of the 3rd party coolers? I'm not sure what I should be searching for.
Thanks!
It's almost a guarantee that any thermal paste that acts like a glue is going to be borderline at best at its intended purpose.
I’ve had pretty good luck just replacing the fan with a new one and leaving the heatsink as is on these. Although I’m sure maximal future proofing would involve an upgraded heatsink I’m not sure that’s really necessary.
What did you replace the fan with?
