Hi all
This is my first post here, I found this forum while googling for an issue I am having with an SE I am repairing.
Basically, the whole ADB stopped working in between reboots - no, I did not hot-plug my mouse! The mouse was working fine before.
The system boots up, reaches the desktop but when I move the mouse, all that happens is that the "apple" menu in the top left corner opens up. Then nothing. But I did not push the button.
The keyboard doesn't seems to do anything. I can open the debug window and all it types are "AA" for each press of the button (AA for pressing and AA for depressing) up to 2/3 of the first line, then it stops. (see pic below)
Things I checked.
- 5V is present on ADB
- GND is present on ADB
- Interference filter is ok
- I checked for continuity between ADB ports, ADB chip and VIA.
- I checked R14, R15 and the transistor driving the bus from the ADB chip side.
- ADB chip is getting a clock from the GLU chip (3.6Mhz)
Then I fired up my scope.
- ADB signal is present on the bus. Additional signals appear when the mouse is moved.
- I decoded the signal sent by the ADB chip: when just booted up, it's asking address 2 (should be keyboard by default) to "TALK". As soon as I move the mouse, the address changes to "3" which should be the mouse. That seems healthy to me. (see pic below)
- I followed the signal out of the ADB into the VIA. I see signals happening between the two chips when I move the mouse.
- I see extra IRQ signals and "Chip Select" on the VIA when I move the mouse.
The mac repair started with some memory issue so I thought that maybe the RAM addresses where the VIA stores its bits could be damaged. I downgraded the RAM from 4 to 2MB, swapping SIMMs but the issue did not change.
I swapped the mouse with another one and the same happens.
So:
- The issue seems to be on the logic board
- The ADB chip seems to be doing something.
- Signal seems to reach the VIA and get deeper in the Macintosh's guts
At this point I am a bit stuck. I am thinking that maybe the ADB is sending rubbish signals to the VIA (or maybe the VIA is) and the software/hardware receiving the signal is struggling to interpret them? I have some other SE, I could socket the ADB and VIA and test but I also like to understand things so I was wondering if any of you had any ideas of what could be going on here!
I've added some relevant schematics 'cause I know they're not so easy to find!
Thank you so much for your help and Happy New Year!
Things I checked.
So:
