SE/30 mouse issue.
Yes. I've attached the SE/30 schematic. The first page has the PDS slot. Pins 4, 44, and 84 are the 3 Interrupt ReQuests (IRQs). Slot pin 84 (IRQ1) should have continuity to pin 2 of the chip at UK11 (page 4 of the PDF). Pin 44 (IRQ2) should have continuity to pin 3 of UK11, and pin 4 on the slot should have continuity to pin 4 of UK11.
Thank you :)
Hi, same issue here with a stock recapped SE/30. Click and keyboard are working fine. But the mouse isn't moving. Already checked broken traces underneath the ADB chip and VIA2, I even looked at the microscope, but no broken traces. What should I check next ? My analog board works fine.
