Glad to see it's showing some signs of life now and that the new oscilloscope is working better.
It's probably kicking and screaming as I take it through it's timing paces
But I'll be damned if it's not working! Just a few hiccups
What's a fun project without hiccups though.
I'll admit, I took the whole thing apart, labeled every IC, and gave it a nice scrub, soap and water. It'll get another over in 91% IPA after it's dried for a bit.
Just some house cleaning as I now have to wait for IC / new resistors.
Only way I can imagine that resistor blowing up is if it was already damaged; it should never have enough of a voltage drop across it to cause that in this circuit.
Think so? I can see that. I don't think this machine would see differences so massive to blow it out. Especially since I'm using a new power supply / cable. Shouldn't throw anything weird I imagine.
I also had R86 blow, or at least look like it just split in half. Which would make sense why my sound doesn't work now.. whoops. Probably the problem, I'll get to sound when I get there.
From the sound and serial logic.
Dumb question though.
What is the risk of using the machine without those resistors? I assume it would just stop those specific circuits. In this instance things I don't care about at the moment. Sound and keyboard.
Those 2 resistors also I can't get the bands off of. When desoldering the
real one that went boom, it basically crumbled to nothingness.
Looks like just a 1k ohm resistor for the kvcc, and a 1.1k for the sound
Sound
Keyboard is on previous page.
I imagine I could use a 1k for the kvcc is:
Brown, Black, Red, Brown. (I can see the last 2 bands red, brown barely on it)
The other one would on sound and logic 1.1k. All I can see on this one is middle brown then red.
Brown, Brown, Red, Brown
That seems right at least.
