TrueAnd the reset/interrupt switches, one of the common mode chokes, bourne filters and RTC?
But you can’t use pick and place if you go for a non-green board anyway…For anyone still interested in buying a PCB, JLCPCB is out of stock on some of the bottom board SMD parts so that's the hold up at this point. I'll likely get purple or blue boards. I'm planning on 10-15 as I have at least 5 SE/30's myself that could use new boards.
You can, you just have to use Standard assembly which costs more.But you can’t use pick and place if you go for a non-green board anyway…
I'm still in for one of them (two if you need help getting enough to order), so keep me on your list! ... and any color is fine.For anyone still interested in buying a PCB, JLCPCB is out of stock on some of the bottom board SMD parts so that's the hold up at this point. I'll likely get purple or blue boards. I'm planning on 10-15 as I have at least 5 SE/30's myself that could use new boards.
Same here. One board; two if it helps getting the order through (or getting into a different volume discount region).I'm still in for one of them (two if you need help getting enough to order), so keep me on your list! ... and any color is fine.
I have 1-2 sparesI'll be interested but I'm in the EU. Any europeans for a small batch?
I managed to find a strip of 10pc in a warehouse in ChinaThat's cool! Where did you get the GLUEs from?
I only have a single spare board left which I intended to build myself once I finished my Classic Reloaded board. If it should turn out that I won‘t have time to build it in the next months, I might sell it including all relating components (almost everything except the ASICs).
Grüezi, I would be interested in your mouser parts list, I´ll order some boards too and need some parts. Thank youI only have a single spare board left which I intended to build myself once I finished my Classic Reloaded board. If it should turn out that I won‘t have time to build it in the next months, I might sell it including all relating components (almost everything except the ASICs).
I can also help with my mouser parts list if somebody is interested…
One of those 10 should be donated to science for the purpose of revere engineering a modern replacement!I managed to find a strip of 10pc in a warehouse in China![]()
I already sent one out to get it imaged when the logicboard project first started:One of those 10 should be donated to science for the purpose of revere engineering a modern replacement!
c
