Opcode MIDI translator and LCIII
I bought an Opcode MIDI translator (not the II) with no cable. Which 8 pin DIN cable do I need? Would the 590-0340 cable work?
Ok, that helped. I cut my cable and mirrored the pins now OMS 2.3.1 can see my MT-32pi and I can play a mid in Musicshop.
So how can I get Hoyle Classic to use this? It says it needs Midi Manager and the extension is enabled, I just don't know how to configure it. The game starts then says Could not find Midi Clients or Ports.
Thanks!
The Sierra games have an installer you'll have to run after you get the MIDI Manager etc. set up. Presuming you tried this but you do need to run that to choose the sound driver. Some copies of games omit the mt32 driver file, you should see it there with the game files.
Thexder was an easy one for me to get going, give that a shot.
Thanks!
Where did you put the midi extension? I found out that it only works if you do NOT put it in the extensions folder. https://www.savagetaylor.com/2019/12/11/connecting-your-68k-macintosh-to-a-real-or-emulated-mt-32/
Ah wonderful. Putting Apple MIDI Driver and MIDI Manager in the root folder did the trick. Hoyle Classic started up right away and sent sound to my MT-32pi. Too bad it is pretty slow on a LCIII. I also tried Thexder (v1.0.1 from Macintosh Repository) and it started but then died with an error. Maybe it doesn't like system 7.5.3? Regardless, seems like it is working now, thanks for the help!
Nice!
Echoing what I said before about system 6, that is what I used for thexder on an SE. Have not tried with my LC II recently.
