I was thinking the same thing about my PowerBook 100. I modified the case so it now has a 1400 KBD. The lid has had the LCD from a 2300c inside for the 20 years since I started the project. The 16bit 640x400 16bit(?) portion of its LCD is a perfect bezel fit!I wouldn't be so troubled by some of the more modern systems (the G4 PowerBooks for example) if the keyboards were more consistent, otherwise I think one of my favorites would be the 12-inch G4. That's mighty cute, small and light. Maybe a 1400 keyboard in that!
Back then, turning PowerBooks into picture frames was all the rage. I was turning BabyPB into a Color slide show player.
I hear you about Trackpads, hate 'em. But after breaking into the 'Book scene from the Duo 230 and PowerBook 100 (PERFECT trackball size) when I collected my first 1x0 the trackball felt like the size of a Kensington 8-Ball, which I also hate.
