I’ve been working on restoring a Macintosh Performa 450 for a long time now. I’ve had one problem after another. Today while attempting to install the internal version of the BlueSCSI, something went wrong. I guess it’s been terminated and doesn’t need to be because the floppy and mouse quit working. I thought I fixed that earlier, but I guess I was wrong. Before I realized the problem, I tried to put a floppy disk in the drive. It didn’t work, and I thought I’d put it in the wrong way. Because I have an automatic floppy drive and didn’t know it wasn’t even running, I attempted to remove the disk myself. It didn’t work. I realized my problem too late after jiggling the disk around too much. Now it’s jammed, and because I used pliers and got it partially out already, I assume my floppy drive is now damaged. I have a spare 1.44mb floppy drive from a PC, but it doesn’t have the same floppy connector. are the read/write heads replaceable? do I even need the second drive’s parts or can I just salvage the first? Why if I thought I’d fixed the termination issue on the BlueSCSI did it continue to persist?
