IIfx Sadness
Welp that’s what I get for buying a machine that didn’t have pictures of the inside. :( This thing is a total write off :( major bummer.
Holy crap dude, that is a terrible loss :(. Not that I’m a shark that has been waiting for a bite…but any way you’d sell the PSU and some of the NuBis covers, if you aren’t looking to repair it?
That's the worst bomb damage I've seen on here. How does that even happen?
I'd also potentially be interested in some parts if you were to part it out.
Yep, there are things that can be saved there.
I assume it was two Maxells that did that amount of damage.
No worries at all, I would like to salvage anything I can from it to recoup whatever I can. Not sure what's of any value or not, I have a Mac II I'm fixing so I need to see if anything from this might help with that effort but after that everything is game. I'm not 100% sure which parts may be cross compatible between IIfx and II
Looks like just maxell battery damage really, I threw the totally destroyed holders and batteries away without taking a picture they were just kicking around loose in the case since the pins to the holder had long since corroded setting it free to bomb around the case :(
Save the CPU, FPU, and RAM at least.
Will do, do you know if those are compatible with a II? I have one I'm trying to fix, but not sure if they are the same.
You know the deal, freaking maxells. :(
Probably some stuff I can salvage, as mentioned by a few folks, FPU,CPU,Mem,PSU, and some assorted case parts, video card might still be good to not sure about that, I'm sure the drive is toast although I'll check it it's a massive 8x6" beast I've never seen a scsi drive like that before. And the floppy might be good for a second drive in my II if it works no idea. Case shielding is rusted all to pieces but the plastic is in ok shape all covers and buttons present, but has yellowing like they all do pretty much.
Ah well I gambled and lost on this one, but oh well, never know what you're going to get. :)
The RAM and CPU are definitely not…in fact, the IIfx RAM is not compatible with any other Mac. It would be valuable to someone else with a IIfx, however.
Also, in my experience, the 5.25” drives are more robust…it may still work.
If its a good video card, it might offset your purchase substantially, if it worked. Hopefully it survived.
I don't think it's anything special just a stock Mac II card. It does look to be undamaged though.
That's good to know I'll check the drive it is a beast so perhaps your right and it still works. Any of this stuff that's not compatible at all with the II is definitely going to be available guess I need to make a trade post of those things whenever I figure that out 100%.
I'd be up for the RAM. Have a part set (3) of 4Mb IIfx RAM - came out of another bombed IIfx. The guy tossed the damaged SIMM, then sold the rest. Difficult to test with just three, so maybe one good set could be made using yours? 🤔 LMK if you're willing to part with what you have as-is.
Send me a PM and maybe we can work something out.
Looks like there are two kinds I’m unsure of the size haven’t looked up the chips yet. One sim was damaged very badly so I have 7 that appear to be at least physically ok.
