Holy crap dude, that is a terrible loss
. Not that I’m a shark that has been waiting for a bite…but any way you’d sell the PSU and some of the NuBis covers, if you aren’t looking to repair it?
No worries at all, I would like to salvage anything I can from it to recoup whatever I can. Not sure what's of any value or not, I have a Mac II I'm fixing so I need to see if anything from this might help with that effort but after that everything is game. I'm not 100% sure which parts may be cross compatible between IIfx and II
That's the worst bomb damage I've seen on here. How does that even happen?
I'd also potentially be interested in some parts if you were to part it out.
Looks like just maxell battery damage really, I threw the totally destroyed holders and batteries away without taking a picture they were just kicking around loose in the case since the pins to the holder had long since corroded setting it free to bomb around the case
Save the CPU, FPU, and RAM at least.
Will do, do you know if those are compatible with a II? I have one I'm trying to fix, but not sure if they are the same.
Yep, there are things that can be saved there.
I assume it was two Maxells that did that amount of damage.
You know the deal, freaking maxells.
Probably some stuff I can salvage, as mentioned by a few folks, FPU,CPU,Mem,PSU, and some assorted case parts, video card might still be good to not sure about that, I'm sure the drive is toast although I'll check it it's a massive 8x6" beast I've never seen a scsi drive like that before. And the floppy might be good for a second drive in my II if it works no idea. Case shielding is rusted all to pieces but the plastic is in ok shape all covers and buttons present, but has yellowing like they all do pretty much.
Ah well I gambled and lost on this one, but oh well, never know what you're going to get.
