Upgrading a Mobius 030 board
I recently acquired a SE FDHD with a Mobius 030 board that I'm trying to upgrade with a full 030 CPU and 16MB of 60ns ram.
I'm having difficulty figuring out how to remove the existing ram from the Mobius board. Instead of the usual SIMM clips the Mobius 30 pin sims seem to be locked in place, and I'm either overthinking it or I need some sort of special tool to get them to come out.
Anyone have experience with upgrading the memory on these boards or a similar type of connector?
I've got one of those with my boxed Novy accelerator. I can take measurements and detailed photos if needed.
Basically it's just a square shaft that fits into the edge of the SIMM socket. Then there's a pin on one corner that fits into the hole on the SIMM and disengages the locking pin. By turning the tool the SIMM then gets ejected from the socket.
You know you are in trouble when you google “SIMM extraction tool” and one of the top hits is ….. this thread.
I bought one of these from these people in 2019 for $6.18: https://www.btw-electronics.net/
However it seems to no longer be listed on their website. Perhaps you could try contacting them? Part number 382264-1
There's the 68EC030 and indeed it comes without a MMU. You won't be able to use virtual memory/Compact Virtual with an EC chip.
So to actually make use of more than 4MB of RAM on the accelerator you want a full 030.
