I've been unable to ascertain what exactly the Splat extension does or where to locate it. This is all that Find File turned up...
Every time the SE boots up, these programs immediately start...
...and I'm unable to find a way to uninstall them or at least stop them from starting up after every time the SE boots. It's really annoying because I'm sure that whoever created this image meant well but I don't need these programs and HAND-OFF II isn't even complete anyway.
There's nothing in Control Panel that provides the option to remove or disable them.
Deleting the program folders hasn't made a difference because they still appear after the OS has booted.
The set-up is slightly different - the files were located inside the System 6.0.8 folder - it doesn't appear to have a startup one. I sent them to the trash, emptied it, rebooted and the annoyance was at an end.
Yes, control panels and extensions live in the System Folder in 6.0. They were moved into subfolders in 7.0 to help clean up the system folder, because it was getting extremely chaotic
Well, it's a good idea! Especially if you had a second "Rated R" version where your mouse splats against the edge too hard, it'll leave blood splats and start trailing blood after a while.
