Does anyone have anything like the MacClip Jr.?
I'd like to take a whack at recreating some of these "clip-on" variable speed overclocking devices. They seem like a very good candidate for 3D printing a very, very simple circuit design. I used to have one from "XLR8" in a 6100/60 about 25 years ago that clocked the machine to 80+ MHz.
I just have no sample to work from anymore, unfortunately.
I had one before I gave it away, so I can at least describe it. The circuit is iirc a clock, multiplier, and divider, with DIP switches to pick the exact multiply/divide values.
Here's a pic from this site,
Basically, it's three PCBs, with a spring in the middle that very slightly pushes the sides apart. The contacts, which you can't see in that pic, are kinda funky, there's a cutout in the PCB and a little piece of metal soldered on with a bump that touches the legs of the oscillator on the board.
See this highly technical diagram I just fingerpainted:
FWIW there are projects elsewhere that are a modern-day interpretation of the concept. It's not a "clip-on" solution, but a solder-on solution.
This one, for example: https://ameblo.jp/keroxiee1016/image-12707256744-15024022337.html
This is, clearly, a much more permanent solution, but for the able-handed with soldering, it also has the virtue of not popping off (a phenomenon I have yet to witness in operation with a properly seated device; though others have offered their own experiences to the contrary).
Here's some pictures of the XLR8TOR (same as XLR8?) WarpFactor 135.
Haven't had a chance to test this, but seems relatively simple.
That's exactly the kind I used to have! The XLR8TOR one. I had it as part of a bundle that included an L2 cache module and a 601 heatsink w/ peltier plate on it (seemingly the same as the one that comes stock on an 8100/100. Though in a 6100 case the peltier hurt more than it helped unless you really rigged up an improved airflow solution.
The MacClip Jr. is different than I imagined it, but also pretty tractable as a project. Definitely going for the solderless approach for this thing, I like that they're trivial to install and remove when they just clip onto the surface mount clock IC.
Great context and photos! Thanks everyone!
My current thinking is that the sweet spot might actually be a blend of the XLR8TOR approach with the approach @cy384 took in the Ultimate Centris 650. Basically a little fitted block that grounds the stock chip's enable pin and exposes a socket on the other side to swap and plop in different speed cans.
The MacClip Jr. is comparatively involved in terms of fabrication.
Yeah, that sort of thing with @cy384's socket design converted to a super simple little PCB would be very straightforward. Socket on PCB, through pins pressed into mold w/ metal contacts in it.
