So, my father's Quadra 660 AV finally got so brittle that one tab of the case top cracked off. I managed to get the other off without snapping it by wedging a flat head screw driver in between the tabs and pushing the one from the bottom of the case in. You can still see the stress lines forming on the other tab though. I had a thought: why not just grind off the angles of the tabs on the bottom of the case? Sure, the case will never be totally secure, but how often are you flinging the machine around so that the case comes off? Has anyone done this before? It stinks that this occurs, but we all know it is Apple's fault.
I can only hope that someday @maceffects sets up a premier, world-renound operation that sees all plastics reproduced someday!
