Getting chime then Sad Mac 0000000F / 00000002 whenever connecting an external SCSI2SD to a Mac SE.
I've tried the following:
- Changed out the ROMs to newer FDHD versions
- Connected to external CD-ROM which worked okay
- Made sure internal HDD was set to ID0 (since the volumes of the SCSI2SD are on 1,4,5,6.
- Disconnected the internal HDD
- Checked voltage rails OK
This SCSI2SD works fine on many other Macs.
Any ideas for what to check next? I'm kind of at a loss since SCSI seems to be working fine with the CD drive.
