M5126 Portable SCSI Boot Issue
I am working to repair a M5126 backlight Mac Portable. Recapped, repaired a few traces and I have the machine doing a good happy chime but when I connect an external (with power and correct INI file) or an internal bluescsi (portable version) it will still give me a good happy chime and then then the SCSI light will blink once and I get a Sad Mac 0000000F/00000002 error code. I have traced out the RAM logic schematic made by Danny Cellar and found no issues. I have gone over the SCSI, IWM to try find broken traces and other new found. I have tried different SCSI chips where some will not give me the sad Mac error but I get the no boot image found icon instead.
If anyone could have any suggestions to try to solve this problem would be very much appreciated.
Thank you in advance
sounds like a bad or poorly configured scsi emulator. I think I was getting a similar error with the scsi2sd I put in my McPortable..
have you tried with a different scsi emulator? zulu-compatible or scsi2sd?
also try booting from a floppy and seeing if you can format
moreover, check your scsi adapter cable or board.
I use same blueSCSI on another portable same model with no changes to image and it works fine. Both internal and external.
Check here. Again, verify scsi.
Thanks for the link, I looked over it but was not so much helpful with my condition. I feel 100% that it is not the scsi device I am adding to the board as both of them work on an identical board with no issues. Still more to try and if any other ideas you have post them.
