ROM needed for an Asante MacCon+IIET
Is it against the rules to ask for a ROM for a Nubus Ethernet card? The one in my MacCon+IIET catastrophically failed and the dump I took of it before it failed is a bad dump as it's 90% 00.
Those declaration ROMs are tiny. Did you try your dump? I’d guess it works.
If not i’ll have a look into my Nubus cards box, I have a few different Asante cards flying around in there...
I did go ahead and burn it to a new ROM but the diagnostic tools and installer still can’t find my IIET. I’m trying to see if it truly is the dump I made that’s bad or if the failed eprom blew up some other parts of the card.
I’ll check my cards and dump the ROMs on there.
What does your card look like? Going to check if I have one that’s an exact match.
This is the one I have. EPROM is a 27C128.
