I am also very interested in this project, and I would love to replace the PSU in my IIsi with a modern one. What is the current status of the IIsi board version you are working on?I am interested in buying an adapter for IIsi when you are ready to sell/ship. Thank you for creating this useful adapter.
I could, but I don't have much reason to. I don't think I've ever seen one of those fail. It wouldn't be hard since it's just a repinning of current design, I'd just not see much use.Any chance you'll be doing a version for the Quadra 630 thru 6500 series?
There's a little bit of a difference between the non-PCI 63x/62xx/63xx and the PCI 6360/64xx/65xx series: when viewed from the top with the edge connector toward you, the non-PCI boards have their power pins arranged left-to-right 12v/G/G/G/5v/5v, while the PCI models are 12v/G/G/3v/5v/5v. So you can't just slam a 6500 board into a 62xx even if you're counting on the 6500 board to supply its own 3.3v PCI power because the edge connector's 3.3v line would be connected to ground. It's possible you can cut the offending ground line at the harness so that it's no longer connected and run your 6500 board that way, but I've never tried it; I've always just built a 3.3v VRM into the harness.That bracket is a thing of beauty
6XX and 6500 would be the same as I understand it. 6360/6400 require 3.3V for PCI whereas TAM/6500 roll their own 3.3V on the MoBo. PowerCC lore is full of SoftPower and 3.3V bugaboos and a recasing someone was doing here of somethingorother in the series had me curious about your plans. Those machines aren't all that much newer than the IIsi/LCs/605 in terms of PSU's in terms of breathing their last, so I thought to ask.
Here's the thing: We already have that implemented in the II Compact board since there are some Macs out there with soft power circuits that have failed. It's an optional part of the board and we won't be shipping wire or a switch to use it, but the option is there with a dedicated header for it so you don't have to go look up an ATX schematic and do some hacking.Maybe if an adapter is built for the 610/660/6100 you can just short the PS-ON circuit so that the power supply turns on as soon as the rocker switch is turned to ON (you'll need a switch-equipped power supply of course). One day perhaps you could build a universal mAcTX board that uses interchangeable harnesses and have a jumper that shorts the PS-ON circuit for hard-power Macs or is removed for soft-power models. All of these computers usually have pretty standard voltages, it's just a question of whether or not they're used; the different harnesses would supply or leave blank any lines as necessary. If a weird voltage was required, a resistor or other passive component could be built into the harness.
I've been rethinking the connectors used in the 630 type and PCI type harnesses. Ran across a Molex pin extractor/installer tool this week and remembered it being used to rearrange pins in a G4(?) ATX conversion. Haven't got a PSU handy, so I've been wondering if that power connector series could simply be removed and the wires/pins from the harness removed/rearranged/reinstalled in the connector from an ATX power extension cable?There's a little bit of a difference between the non-PCI 63x/62xx/63xx and the PCI 6360/64xx/65xx series: when viewed from the top with the edge connector toward you, the non-PCI boards have their power pins arranged left-to-right 12v/G/G/G/5v/5v, while the PCI models are 12v/G/G/3v/5v/5v. So you can't just slam a 6500 board into a 62xx even if you're counting on the 6500 board to supply its own 3.3v PCI power because the edge connector's 3.3v line would be connected to ground. It's possible you can cut the offending ground line at the harness so that it's no longer connected and run your 6500 board that way, but I've never tried it; I've always just built a 3.3v VRM into the harness.
I just looked and it appears that you can: the offending ground wire has its own connection at the power supply header, so depending on which board you want to use it could be made to go to ground or 3.3v.I've been wondering if that power connector series could simply be removed and the wires/pins from the harness removed/rearranged/reinstalled in the connector from an ATX power extension cable?
Oh no didn't take it that way at all, we just haven't really gone into the specifics of what else the boards can do... which right now is pretty much just that bypass switch@blusnowkitty, not trying to be down on your efforts. On the contrary: I applaud them. Great work. Happy to help if I can. I just wanted to add some thoughts should you decide to add support for more models in the future and possibly consolidate to a universal board to reduce costs.
