Curious about exploring the possibilities in general over the Audio's four wire connection which needs be rejected out of hand for lack of +5V. I'd earlier wondered if a USB KVM switch could be used to run ADB over the USB wiring, but @Gorgonops pointed out some reason or other that it was impossible. Now I'm curious about using a USB KVM+Audio Switch as the basis for an ADB KVM switch? I'm also wondering if USB +5V line would be compatible with ADB requirements? Between USB Power/ground and Audio's pair of signals +- Microphone there should be plenty of signal lines to do ADB?
Goal: design a PCB combining compatible assortment of KVM+Audio signals at the Mac end similar to the PS2 based MiniView Mac Converter:
Project would remove the manual ADB/Video KVM switchbox out of the picture entirely, with each Mac connected directly to a "MicroView" adapter and a modern USB KVM+Audio Switch like the four way unit I'm using now would replace the MiniView A/B PS/2 KVM. The only drawback I see ATM would be lack of connection to a "real" USB KVM, it would be an ADB Mac only bodge. Should the baseline project be workable, I'm sure adding a single USB to ADB Wombat solution will be workable, but that's for another thread.
https://old.pinouts.ru/Slots/apple_adb_pinout.shtml
https://pinouts.ru/HeadsetsHeadphones/
In simplest form, a Pair RCA jacks yield two signal lines and ground
https://pinoutguide.com/Audio-Video-Hardware/rca_connector_pinout.shtml
Dunno iv USB KVM+Audio would be +Microphone or not
________________________________________________________________________________________________________________________________________
OK, I got carried away with the intro. :
So the original project/inspiration for the above had been relegated to IP tangent status. I have an Extron SW6 VGA Audio switchbox that has five lines available.
So of course I'm wondering about reduction of the switching circuits for audio to the least common denominator. Pulling ICs at one level or the other will probably be necessary to re-purpose one of the Audio ground lines as the +5V line of ADB.
I'm hoping it can be done at this level by pulling the INA137 AUDIO DIFFERENTIAL LINE RECEIVERS?
