Dear all,
I'm struggling to make an EMTEC 4GB sdcard work on my Quadra 700 with a scsi2sd v6 board.
I've followed Steve's installation step by step (http://www.savagetaylor.com/2018/01/05/setting-up-your-vintage-classic-68k-macintosh-using-a-scsi2sd-adapter) and all went fine until I switched the IDs (from the disk where I copied his 755_2GB image to the disk where I installed OS 8.1).
[SIZE=1.4rem]After switching IDs, making ID 0 the disk with the OS8.1. installation, I either get a "bus error" after the OS starts loading or, if I try to boot with extensions disabled, it hangs.[/SIZE]
Any ideas? I have a very standard Quadra with 64MB of memory. No additional cards installed. 100% stable running OS 7.6.1 from its original IBM SCSI drive.
Thank you all in advance for the invaluable knowledge sharing in this forum!
lG
lG
